Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
Where is the pressure relief valve on a briggs and stratton pressure washer
5 Suggested Answers
  • 1111 Answers
SOURCE: just bought a new Briggs Stratton 6 75 pressure
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
Posted on Jun 20, 2009
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
roadtech7
  • 297 Answers
SOURCE: How do I winterize a
Change engine oil, add fresh stabilized fuel,start and run to circulate new fuel. Use a section of hose and pump som RV antifreeze (the pink stuff) through your pump and hose if you are leaving your hose and wand hooked up.
Hope this helped
Posted on Nov 04, 2010
  • 1267 Answers
SOURCE: The 6.5 hp Briggs & Stratton engine that
It most likely is a ring problem as the gasket only keeps the combustion gases in and would leak around the head as a loud noise. Of course it could be the valves, but I doubt it as most of these engines are splash fed instead of pressure, so the only explanation is the compression ring is letting oil blow past.
Posted on Jan 03, 2011
Pressure washer has no pressure at all
check for blocked jet at the end of the wand
this is the same as letting the trigger go and the pressure relief regulator is not engaging the pump to produce pressure
water just circulates around the pump
Jun 30, 2015 | Briggs & Stratton Garden
Will not produce pressurized water
check the pressure regulator valve. It may be set wrong or stuck open. If that is not the problem then a valve may be stuck in the pump.
May 17, 2013 | Briggs & Stratton Briggs Stratton 1800...
Troybuilt pressure washer shooting water from relief valve as soon as start it
Sounds like the hose or some piping is clogged after the relief valve.
Aug 15, 2012 | Briggs & Stratton Garden
Where is the fuel shut-off valve on a briggs and stratton 2100 psi model 01439
a lot of the dont have one but a small inline valve can be installed the fuel dripping from the carb when its turned off replace the needle valve and seat
Mar 29, 2012 | Briggs & Stratton Power Products 1539...
Pressure washer only works if you crank it with pressure handle open , then works great if you let off it builds up pressure . and no water will come out when handle held fully open , bleed off pressure...
Hello..the unloader valve on the pump where you attach your water supply and your pressure outlet hose is the problem.There is a spring relief valve that is most likely frozen and not allowing the water pressure from the pump to circulate within itself.They range from 60.00 to 150.00 depending on your make and model.
Aug 19, 2011 | Briggs & Stratton Pressure Washer...
Does not put out pressured water
Rebuild the water admittance valve, sometimes called pressure relief and other names. The valve has a spring and when you trigger the wand reducing the pressure behind the valve spool reduces and the spool moves letting IN more water to be pumped. Disassemble the valve. Clean the bore with crocus cloth on dowel rod... deposits build up. Replace O Rings on the spool and lube with plumber's grease and re-assemble.. Good as new!
May 08, 2011 | Briggs & Stratton Garden
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
