Question about LG Hbm570 PurpBluetooth Wireless Headset Hbm 570
How do I set my Bluetooth headset to alert me to who is calling?
    Master:
  • 697 Answers
You can't. It has to be done through the phone.
Posted on May 15, 2014
2 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: How do I set my Bluetooth Headset HBM-730 to discover mode?
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HBM-730 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Instructions:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
Have a HBS 700 that pairs with device and was working but now still works but no sound.
check volume control to full,,,,,otherwise speaker inside it=defective
Jun 07, 2015 | LG HBS-700 Bluetooth Headset
Will the bsh-100 pair with Iphone4s?
Yes. Starting with the iPhone 4 and newer, all support the following Bluetooth Profiles: A2DP(high fidelity stereo sound for music) , AVRCP(remote control, letting a headset's buttons change tracks, volume, etc), Handsfree and Headset(answer and make calls using the headset) , PAN (tethering a laptop to your cellular data conndction), PBAP (allows access to your contacts/phone book), HID (let's you use input devices like Bluetooth keyboards to type on your phone), and MAP (lets a bluetooth device send texts and get alerts if you receive one). Any bluetooth device with any of those profiles will work.
The BSH-100 uses the A2DP, AVRCP, Handsfree and Headset profiles, all of which your iphone supports. So all features will be enabled and work flawlessly on your phone.
Mar 06, 2015 | Anycom BSH-100 Bluetooth Headset
Can not get my Jabra Bluetooth to accept my calls
So here's some info on the bluetooth headset:
http://headsetplus.com/product690/product_info.html
Also, Jabra's tech support is solid. Consider giving them a call if you still can't figure it out. GL!
Oct 14, 2014 | Plantronics Explorer 220 Bluetooth Headset...
My headset won't stop sending an incoming alert ring continually even when on a call is there a master reset. I have 2 of these plantronics pro and both are now doing this it seems as when you have 2...
If you hold down the power on button while plugging in the a/c adapter charger, this should force the headset into a power cycle on the headset and correct the problem.
Good luck from Headsets Direct!
Mar 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
I need the password for my bluetooth explorer 390
If you forgot your password, please try below instructions:
How to Pair Your Headset If it Has Been Previously Paired With Another Device:
1. Turn the headset off. Press and hold the call control button until the indicator turns red and then turns off.
2. Turn the headset on. Press and hold the call control button until the indicator light continues to flash red and blue. The headset is now in pairing mode.
3. Use the commands on your phone to locate your headset. For most phones, select Settings/Tools > Connections > Bluetooth > Search > 3xxPlantronics. See your phone's user guide for more information.
4. If prompted for the PiN code/passkey, enter 0000.
Pairing is successful when the indicator on your headset flashes blue. Your headset is now connected and ready to use.
NOTE This headset is equipped with Secure Simple Pairing (SSP). If your phone supports SSP, you will not have to follow step 4; you will instead see a message on your phone alerting you to a successful pairing.
Feb 18, 2011 | Audio Players & Recorders
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have purchased a BW900 headset and and trying use the headset on my PC for skype. I have a bluetooth dongle and the PC recognises the headset, however on the bluetooth devices list it has a...
in windows xp!!!
click start
all programs
accessories
entertainment
volume control
click devices
recording devices
check the box for your default device..
Vista / Windows 7
right click the speaker icon to the bottom right of your screen (tl bar)
click recording devices.
click set as default,, you may also adjust and set up the device..
Mar 16, 2010 | Sennheiser BW900 Bluetooth Headset
I need an owners manual for jabra model BT4051 headset
You don't need one. After charging set, press and hold for several seconds until unit blinks repeatedly. Now it's on.
To turn it off, repeat procedure.
Press briefly to take incoming calls, or to place calls if your phone is voice activated. You should hear a beep after each press.
Use + and - buttons to increase/decrease volume.
Unit blinks once, intermittently, when it's ON. That is normal operation.
Note: It takes a few seconds for the connection to occur, after you initiate a call or take a call, and other sounds alert you when the connection is taking place. You'll learn as you go.
Dec 02, 2009 | Jabra BT4051 Bluetooth Headset
LG Hbm570 PurpBluetooth Wireless Headset Hbm 570 Logo
37 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
