Question about Motorola Walkie Talkies 2-Way Radio
Charge time for a motorolla t5
I dont have my manual for the motorola t5. I have no idea how long the charge takes in the drop in charger?
  • 27 Answers
The standard charge time is 10 hours.
If you have a rapid charger about 1 hour.
Posted on Aug 24, 2009
Recently i have purchased Motorola S9 blutooth head set. Kindly let me know what type of motorolla charger to be used 1.5amp or 2 amp since there are 2 chargers available. And also while charging, within...
Bluetooth headsets, like many portable devices can be charged on a USB port on a computer, which supply less than 1A, so either charger would be suitable.
Looking at the manual, a full charge should take two hours, so half an hour seems a little quick.
Perhaps it was part charged?
You could see if you can listen to music for six hours on a charge, and if so how long it takes to charge then.
The manual can be found here.S9 user guide - Motorola
Feb 14, 2011 | Motorola Mobility S9 Headphones
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
Motorolla peble
It's Italian for "unable to charge"
Motorola phones won't always charge with non-Motorola chargers, or via USB connections.
Does it do this with a Moto charger or a generic one?
Dec 21, 2009 | Motorola Cell Phones
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
Failure to charge
The RAZR v3 series won't charge from a standard USB connection, you'll have to get a charger that's made for Motorolla phones.
I've used a generic car charger with no problem, but I had to buy the one that's compatible with Motorolla Phones, not the basic USB-style chargers.
You can also download drivers for your PC that will let you charge with a standard USB cable.
There's an excellent explanation of the drivers in this solution (not mine, but he/she did a great job)
Sep 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Phone
You charging Port need to be service or replaced, so take the phone to a mobile service center to have it fix.
Aug 28, 2008 | Motorola Mobility SLVR L7 Cellular Phone
MOTOROLA T5522 BATERIES
Hello mironas3,
A general rule of thumb when dealing with rechargeable battery packs is to take the capacity of the battery divided by the charge rating of the charger and then add an additional 10%.
Offhand I am not sure what the voltage / capacity or voltage / charge rating of the battery and charger are but you can determine that by examine the labels on both items. Let’s say (for example) that your battery is listed as 7.2 volts and 1,000 mAH and your charger is rated as 9 volts and 100 mA. (These are just theoretical examples. Substitute the numbers from your own items.) You would divide 1,000 mAH by 100 mA to equal 10 hours. Then add 10%. So you expect a full charge to take around 11 hours time.
Of course, actual charge time will vary depending on how discharged the batteries are when you start charging them. Since the charger that Motorola provided doesn't have a charge indicator determining when the batteries are done charging is a matter of making an educated guess. If you touch the batteries while they are charging and they feel warm to the touch, that's a pretty good indication that they are done or nearly done charging as once the batteries are topped off excess power will turn into heat. (Note that batteries in a charger should never be HOT. If they are ever more then just slightly warm, something is wrong with the battery or the charger or both.)
Also, just a word of warning here: remember to always use the correct manufacturer recommended charger. Substituting a charger with twice the charge rate to charge the batteries in half the time is not a good idea. Rechargeable batteries are meant to be charged slowly. Fast chargers exist but they typically have built-in circuitry that pulses the charge rate to prevent the batteries from overheating. Using the wrong charger can result in damage to your battery or radio or worse could possibly even lead to a fire.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 28, 2008 | Motorola T5522 (7 Channels) 2-Way Radio
Motorola v3i
connect your phone to the system through usb. if it starts charging then its not the problem with the phone or battery. its a problem with the charger. now also if it does not charde, then it must be a problem with the phone. take it to the nearest motorolla service centre and fix it.
Apr 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Walkie Talkies 2-Way Radio Logo
170 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
