Question about Onkyo Stereo Audio Receiver TX-8050 / TX8050
I have an Onkyo TX-8050 that shuts off immediately after I turn it on. I saw on line that Onkyo acknowledges that a problem exists with this model and will fix it free of charge. Do you know if this
Shuts off immediately after I turn it on.
This is some serious BUL SH*T. Look Niggazz, I ain't payin' for someone to make a killing off of me. I would prefer to repair it myself if possible. Could you please send me the schematics for the Onkyo Network Stereo Receiver TX-8050. g, thanx :)~
Posted on May 24, 2015
  • 790 Answers
I would search for recalls and the customer support information center.
You should contact them with the model number by email and see where that goes.
Posted on May 15, 2014
simplemitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
thaurfen
  • 623 Answers
SOURCE: Onkyo just shuts off...
check for blown fuses
Posted on Aug 15, 2008
  • 4234 Answers
SOURCE: Onkio receiver
The output transistors should be replaced in pairs. Also, It may not be just the output transistors that are defective. If you have no experience with these types of repairs, I would suggest that you bring the unit to a service shop. The outputs will run about $15-$25 per pair.
Dan
Posted on Aug 29, 2008
hi-fi
  • 25 Answers
SOURCE: My Onkyo Receiver TX 601 is turning itself off
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
SOURCE: Onkyo TX-SV919THX, No Output
I have found the battery location. It is roughly on the opposite side of the pc board where the display is. It basically faces the heat sinks. It's one of those small watch sized batteries and is soldered but sticking off the pc board with 2 leads. I could see that there was some leakage and corrosion. I still have to figure out what needs to be dis-assembled to get access to it so I can unsolder the bad battery and replace it. This stupid little battery seems to need replacing every 6-8 years! When it dies, it seems to disable the preamp section from passing any signal giving the symptoms that the amps are dead. However, if you try to use the pre-outs to an external amp, nothing. So, my guess is it has something to do with the preamp section. Anyway, that will be my weekend project to try to get at the battery and replace it with "longer leads" so it will be easier to replace in 6 years when it dies again. Great design Onkyo! You dumb-*** weasels!!!! I hate when companies engineer things to break so you are likely to pay them to fix it. Not this time, "No soup for you!"
Posted on Feb 19, 2009
My Onkyo TX NR609 is not coming on and immediately shuts off and is progressively getting worse it is hooked to a harmony smart hub
Hi Liz, I am sorry about your issue. Please remove the HDMI cable from the receiver that is connected to the TV as a test. Check and see if the receiver stays on. If it does not the receiver would need to be serviced. Thank you, Onkyo USA
Oct 29, 2016 | Onkyo Audio Players & Recorders
I have a onkyo TX-NR616 receiver which has now for some reason has no sound when fist switched on, however if left on for about 15 minutes then turned off and straight back on again then after a few s
There is an extended warranty coverage that Onkyo is providing on receivers manufactured between 2009-12. Not sure if the TX-NR616 is included, but here is a thread from the AVS forum on the problem:
Onkyo acknowledges failed units and extending warrranties until 2018 AVS...
Feb 07, 2015 | Onkyo Audio Players & Recorders
Set up an onkyo TX-8050 with a wireless connection to Pandora
You need a subscription and registration of your device to Pandora .
Dec 16, 2014 | Onkyo TX-8050 Network Stereo Receiver
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
How do i check to see what is causing my receiver to shut off
Sep 25, 2014 | Onkyo Audio Players & Recorders
TX DS989 turns off after 3 seconds
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Jan 03, 2014 | Onkyo TX-DS989 Receiver
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Mar 24, 2017 | Onkyo TX-NR509
This site said it was free - then there is a charge? I am getting a "Protecting" message when I turn on my receiver - then it shuts off....What does this mean and what should I do?
It means the receiver senses excessive heat, or a short at its outputs. Disconnect the speaker wires and see if that helps. If not, get it to a Tech. If it turns on, figure out which speaker path(s) was causing the problem and resolve it.
The manual.
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Power shuts off immediately after power on.
• Amplifier protection circuitry is activated. Remove the power cord from the outlet immediately. Contact your Onkyo service center.
Jan 13, 2011 | Onkyo TX-SR601 Receiver
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
Onkyo Stereo Audio Receiver TX-8050 / TX8050 Logo
331 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
