Question about Samsung RS2630SH Side by Side Refrigerator
I am experiencing the following problems, loud noise on the refrigerator side which lasted for two days and suddenly stopped, now the refrigerator does not get cold and the ice maker is not making any ice. What may be my problem?
    Problem Solver:
  • 12 Answers
SOUNDS LIKE YOUR EVAPORATOR FAN WAS BANGING ON ICE OR WAS DYING-----DEFROST OR REPLACE FAN
Posted on Jun 02, 2014
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Posted on Jun 17, 2009
  • 119 Answers
SOURCE: Samsung RS267LBBP 26.1 Cu. Ft. icemaker won't stop making ice
UP.
Posted on Aug 07, 2009
SOURCE: Hot refrigerator
Same problem here with the Samsung RS2630SH refrigerator. First had intermittent fan noise, followed by constant squealing fan noise followed by total fan failure and fridge walls getting very hot. Ordered parts # DA97-01949A (fan motor) and DA31-00010C (fan blade) from partstore.com. The fan unit actually slides out. Slide the fan unit (the white plastic cowling and all) forward (toward the doors) and then lift it out. Taking the back panel off and aiming a fan at the condenser does seem to sufficiently cool the fridge - at least it did for me - until the parts arrive. Good luck to all and don't by Samsung again. I know I won't.
Posted on Apr 07, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Replace motorized damper
It may be possible that water is splashing from the icemaker fill tub and running down into the fan area and freezing. When the refrigerator goes into defrost the ice thaws and the noise stops.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
The freezer side appears loud rattling noise and noise stop when the freezer door open. It happens couple times per day and last minutes to hour.Please tell me what's going on this
I had the same problem - A fan in the freezer section has ice building up on it and the noise you here is the fan blades hitting the ice. The fan stops when you open the door. I had to empty the freezer, shelves and all; remove the back panel (a pain in the neck) and chip the ice off of the fan housing. I have to do this every few months.
Aug 03, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
Jun 04, 2009 | GE GSS25JEMWW Side by Side
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Loud noise from Fan and compressor
i have the same problem with mine. I took the back cover off at the bottom and the fan was going. get a scredriver and barely touch the center of the fan while it is on and if it stops making the noise then it is the fan motor. The bearings are getting ready to go out and it needs to be replaced.
Mar 22, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
