Question about Brother MFC-465CN InkJet Printer
Where is the cartridge sensor on brother mfc 465 cn
  • 2072 Answers
SOURCE: Can Brother MFC 5460 CN scan without the cartridges?
That's not a dumb question at all. Actually an excellent on, And I would really think you need to go to Brother.com and call customer supprt. My best guess from knowledge of past equipment experience, would be if the cartridges are ampty or out of the machine, It will lock out and not scan.
Posted on Apr 02, 2008
  • 105 Answers
SOURCE: installation brother mfc 420 cn
For the drivers and manual, you can go to brother's website. Here's the link for your specific printer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc420cn_us
This should enable you to get up and running.
If you need something that is not in that group of downloads, you would need to contact Brother to order additional items.
Posted on May 20, 2008
  • 320 Answers
SOURCE: my Brother MFC 465-CN keeps saying "No paper fed"
try cleaning the paper feed roller with isopropal alcahol
Posted on Jan 13, 2009
SOURCE: mfc 440 cn brother printer does not recognize the cartridge
This is crazy.... It is probably a faulty cartridge, ink jet unit stopped up, or a cable that could be loose in the machine from the main board to the cartridge unit. There is a possiblility that the board could be bad too... This units are made so cheap so that you will buy them and then they charge you alot of money for the ink cartridges. You get disgusted with it and buy another one and that is how they make their money. It is just a revolving cycle all the time with Brother, HP, Canon, Okidata, and Lexmark too...
Posted on Feb 13, 2009
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
My memory is full on my Brothers all in one printer model # MFC - 465 CN. So I can not send any faxes and I'm a buisness owner and needs this fixed A.S.A.P
Hi there!
To be able to send a fax without getting the message that you're out of memory here's what you can do:
-Press the FAX button -Press the up or down arrow key to select Real Time TX press OK -Press up or down arrow key again to choose ON then press OK
Hope this helps!
May 08, 2011 | Brother MFC-465CN InkJet Printer
Can my brothers printer work only on black ink (MFC 465 CN)
I am afraid you cannot print if (any) one of the cartridges is empty. Here is a screen capture from the properties of my MFC. At the bottom of the picture it says in French : Le MFC arrêtera l'impression Couleur/échelle de gris lorsqu'une ou plus des cartouches d'encre sera vide.
What it say in English is as follows: The MFC will stop printing in Color/Gray scale when one or more of the ink cartidges is empty.
Open the properties of the MFC. Under "Advanced" Tab Click the Printing Defaults at the bottom left. At the bottom of the window that pops up you will see the information that I translated for You.
Jun 30, 2010 | Brother MFC295CNAll-In-One InkJet Printer
Brother 465 cn printer. When printing test sheet, only 3 black boxes show up. For each color 20 to 30 boxes show up. Is this caused by a bad print head? How hard is it to replace the print head? Are...
I am having the exact same problem. just 2 squares on first line and first square on the second line. I have replaced the black cartridge 3 times and cleaned it many times. But get the same test print page result. Any suggestion for fixing this problem?
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
Does not print properly-even after installing brand new cartridge
most likely your ink nozzles have clogged up.
try several cleanings, if it still does not work, you probably have to get the printhead replaced.
Jun 26, 2009 | Brother MFC-465CN InkJet Printer
Printer does not see the new cartridge
try use Q-tip with water to clean up carriage the contact copper
Dec 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Mfc 440 cn brother printer does not recognize the cartridge
Dec 03, 2008 | Brother MFC-440CN InkJet Printer
My Brother MFC 465-CN keeps saying "No paper fed"
Nov 26, 2008 | Brother MFC-465CN InkJet Printer
Brother printer MFC 420 CN
I wouldn't be surprised. Since you're going to need black ink eventually anyway, put in a new black cartridge and find out.
Sep 16, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother 420CN
switch off the printer..... remove the cartridges... gently clean the sensor area. re -fix the cartridges and switch on......
dont forget to rate this post.....
Aug 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
