Need Roku 4 digit remote code for zenith zc600 learning remote.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
0028.0022.0025. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Posted on May 15, 2014
SOURCE: Zenith remote codes
i have a nenith remote but lost codes and i have a vcr /tv combo unit tashiba what are the codes ?
Posted on Jun 20, 2008
aprmaejun
  • 97 Answers
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
SOURCE: CODES FOR ZENITH DTT900 DIGITAL TV CONVERTER
Hold Power and press Channel Up or Down. There are 150 manufacturers, so if you don't get functionality within 150 presses in one direction, you're SOL.
Posted on Mar 02, 2009
andy4254
  • 226 Answers
SOURCE: Need Programming Code for Zenith Remote MBR3457
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
Posted on Apr 23, 2009
Have Magnavox remote need a code to program my zenith dtv tuner
Magnavox remote have no set-up code to Zenith DTV. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Dec 25, 2015 | Zenith Televison & Video
Roku
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. 0029,0036,0035,0031. Check these codes first.
Mar 17, 2013 | GE JASRM24912 Remote Control
I need a code for my tv zenith i have a jumbo remote laxmax
Hello
Three digit remote codes for Zenith TV with Innovage Jumbo remote control are:
004 / 005 / 006 / 019 / 196 / 004 / 051 / 083 / 152 / 153 / 154 / 210 / 217
OK.
Jun 20, 2011 | Innovage Jumbo Remote Control
Hi, i need the codes for an old zenith tv, i lost my chart of codes, can you help me up please?
The JASRM24912 uses a 4 digit code and there are a number of codes for Zenith tvs: ZENITH ......................0329 0247 0252 0266
......................0288 0226 0227 0338 0347
......................0353 0358 0245 0229 0310 0232
......................0376 0377 0279 0368 0243 0405
The manual and the code lists are available here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
I hope this helps.
Nov 05, 2010 | GE JASRM24912 Remote Control
I lost the code sheet, and I have a GE UNIVERSAL REMOTE. I need the codes for this remote for a Zenith television.
The code for your GE remote control to programme with Zenith TV are
3 digit code
000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338,358
4 digit code
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0247 0266 0288 0310 0338 0358 0023 0039 0001 0058
Thanx
Aug 04, 2010 | Zenith ZN-501S Remote Control
Im looking for the codes to enter into my universal remotes i have 3 tv's one a rca, zenith, hitachi
Hi! For me to give you the correct code for the 3 TVs I need to know the Model number of your GE remote control because there are certain remote control that need a 3 digit code and some need a 4 digit code. But then you can just try these codes.
4 digit codes:
RCA 0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Zenith 0634
Hitachi 0088 0059 0142 0060 0072 0004 0009 0091 1002 0001 0012 0061 0137 0139 0141 0179 0227
3 Digit Codes
RCA 000, 003, 004, 005, 007, 009, 011, 031, 048, 054, 078, 082, 083, 094, 096, 098, 099, 100, 101, 102, 103, 107, 113, 129, 133, 167, 179, 181, 187, 188, 191, 194, 342
Zenith 000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338, 358
Hitachi 001, 004, 009, 012, 013, 059, 060, 061, 072, 088, 091, 137, 139, 140, 141, 142, 143, 144, 145, 146, 179, 210
Jun 15, 2010 | GE Televison & Video
Universal remote - program digital converter box and Roku?
if you still have your remotes you can program the buttons for each funtion.
1. Hold down P until the red light blinks
twice.
2. Press 9 7 5. The red light blinks twice.
3. Press the device key that corresponds with
the desired device's remote (TV, CBL/SAT,
DVD, VCR or AUD).
4. Press the desired learning key. The red light blinks rapidly.
5. Place the device's remote control head-to-head
(about 2 inches apart) with the
11
Gamer Remote.
6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
Jan 14, 2010 | Radio Shack (15-2147) Remote Control
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Need code for zenith Televison
I don't know if you need the 3 or 4 digit code for your specific remote. I have found the site that provides the codes for your universal control.
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Zenith HDTV
If you have a 4-digit remote, it should be 0634
If you have a 3-digit remote, it should be 634
Zenith standard TV (there's a bunch)
3-digit: 000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338, 358
4-digit: 0121, 0009, 0050, 0078, 0091, 0138, 0059, 0131, 0038, 0111, 0134, 0153, 0064, 0004, 0135, 0226, 0227, 0245, 0247, 0252, 0266, 0288, 0310, 0338, 0358, 0023, 0058, 0039, 0001.
I hope this helps!
T-Mo
Feb 09, 2008 | GE RM24911 Remote Control
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
