Question about Maytag M7DH45B2A Dehumidifier
My dehumidifier says full but the bucket is empty?
I am thinking that something is clogged. I made sure that the filter was cleaned. Unit will turn on but not run because the button for full keeps beeping. I have made sure that it is reseated properly and completely empty.
SOURCE: Full light keeps blinking on Maytag dehumidifier
pull out the tank and see if you can find the switch that actuates that fault.... it may be the float swich for the bucket and it may be stuck... flip the float switch up and down a few times
Posted on Aug 31, 2008
  • 16 Answers
SOURCE: maytag electronic dehumidifiers full light stays on
Take out the bucket and locate the "full" switch in the upper right of the area where the bucket slides in. With the unit on, try pushing it in and see if the "full" light goes off.
If so, that switch is fine - if not try to adjust if and replace it if required. Those are generally micro-switches and firms like Radio Shack would have if your appliance parts dealer does not.
Posted on Mar 30, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Dehumidifier will not run. Indicator light says "full"
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 04, 2010
heatman101
  • 43501 Answers
SOURCE: Empty bucket but dehumidifier keeps flashing full
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
heatman101
Posted on May 25, 2010
SOURCE: My Maytag Model M7DH45B2A REV-A will not turn on. The full light
It's unbalanced .Give it a swat
Posted on Aug 09, 2010
Dehumidifiers bucket empty but says full water leaking on floor
if says full and leaking on floor. it is full, you say empty, why make sure that it is empty, sensor in container to check level, so if it is empty, sensor fault, but leaking on floor, would indicate sensor ok, and container full
Aug 07, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
Says bucket full and it is empty
There is a float switch somewhere to measure the level of water in the bucket. That switch is out of position or broken. This can happen if you are not careful removing and re-installing the bucket. Look at the area around the bucket and you should be able to find and fix the switch. Make sure the power is off when you are doing this.
Nov 13, 2013 | LG LD450EAL 45 Pint Dehumidifier
Dehumidifier doesn't turn on
possible bucket full switch is actuated??
Aug 11, 2017 | Danby Dehumidifiers
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
Unit turns on for about a few seconds and shuts off. bucket full light stays on. Micro-switch is ok what else could that be
Possibly., the unit turning ON vibrates the bucket in such a way, that it loses contact with the safety switch and the unit shuts OFF. If the dehumidifier is not sitting level, it would cause the bucket to shake more than usual. In addition, if you haven't cleaned the filter recently, I would suggest that you do that. A dirty or clogged filter causes the unit to struggle and if it is to much to handle, it will cause it to shut OFF. Before you attempt remove the filter, turn OFF the Master ON/OFF Switch and Unplug the unit. Be sure you do it in the order I listed.
Hope this helps you further to troubleshoot and solve the problem.
Apr 08, 2011 | Kenmore 54501 Dehumidifier
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
52 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
