Question about La Pavoni Europiccola EPC-8 Espresso Machine
Why water drop before lever raised until top position?
I just bought La Pavoni Pro machine few days ago. I found the water drop/flow down before the lever raised until top position. What caused this problem and how to fix it?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
Posted on Jan 03, 2015
  • John Shen
    John Shen Feb 05, 2017
    In my case, the machine is recently bought, within a month.The water comes out when the lever position is required up high and high, probably the water will not come out next month.Just wonder if there is a way to reset the lever position for water to come out.
SOURCE: no pressure
The relief valve has a toggle inside that is heat activated. This can stick. I found if you tap it with a spoon the toggle will release and the valve will close.
Posted on Sep 29, 2007
  • 2039 Answers
SOURCE: lever pressure
clean up time use a product to remove calcium how many time i saw that calcium ruining very good machine hard water is a killer of those beloved machine dont use vinegar not strong enough and dont forget to rinse the machine very good that stuff is very corosif dont forget to rate this good luck cheers
Posted on Jan 16, 2008
  • 46 Answers
SOURCE: La Pavoni Losso Espresso machine not working.
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Posted on Feb 09, 2008
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Posted on Mar 28, 2008
  • 944 Answers
This problem could occur due to to two problems.
1)Blockages in the valves.There are many valves present that will cause this issue.
When it is blocked due to dust particles it will block the flow.Check in the the diagram of how
to separate the La Pavoni.Apply some air pressure at the valve knob endings and the flow turnings.
2)Piston may to block the flow.So take it clean and place it properly.
Here is the parts diagram which will help you take apart the La Pavoni.
For clear picture and more details:
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 16, 2010
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
Feb 05, 2017 | La Pavoni Coffee Makers & Espresso...
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
on Jun 02, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
On my 6 momnths old europiccola no water coming into group
Hi, I have the same problem, i bought mine this summer so we have had bad luck , we call it mondaysamples here in sweden, im still investigating how to solv it, keep me updated if you are lucky, i will send you info if mine will be fixed /Peter
Jan 02, 2013 | La Pavoni EUROPICCOLA EG-8 Espresso...
Espresso comes out of comes out of spout before handle is raised
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at
All the best
Mr La Pavoni
May 14, 2010 | La Pavoni Europiccola EPC-8 Espresso...
On a La Pavoni europicola which way do the piston seals get installed, both the same way or opposite to each other?
Normally on lever machines the top seal sits with the cup area(slash in gasket) facing up and the bottom facing down.
May 16, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Lever pressure
Jan 16, 2008 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
110 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
