Question about Dryers
How do I replace igniter in Maytag Admiral AGD4475TQ1 gas dryer?
  • 39 Answers
First, you may have to turn off & disconnect the gas line and line-bracket to the dryer (rear of dryer) (because the manufacturer saved by excluding a shut-off valve & disconnect in the unit). Disconnect the cable connector to the valve. Remove the screw(s) on the bracket holding the gas valve/burner/ignitor/etc.CAREFULLY slide the valve/burner assembly out of the unit. CAREFULLY remove the ignitor and replace (part # 279311). Re-assembly in reverse order.
Posted on Jun 05, 2014
4 Suggested Answers
  • 91 Answers
SOURCE: maytag gas dryer
exhaust hose kinked if not have exhaust line cleaned out ,,,
Posted on Jan 03, 2009
richroth
  • 9472 Answers
SOURCE: I have a admiral dryer model # AGD4475TQ1 ...we turn the gas off now there's no heat how do we relight the pilot
There is no pilot lite on that model, it has an igniter that glows and ignites the burner. There is a small access hole on the bottom left side of the front panel. Remove the cover, start the unit and see if the igniter glows. Post back the results.
Posted on Nov 25, 2012
small6363
  • 18424 Answers
SOURCE: I have the admiral dryer agd4475tq1 and the gas was off for construction now the heat don't work
you've got air in the system you need to let all air out before gas gets to the ignitor..
Gas valve makes a buzzing noise in my AGD4475TQ1 Admiral dryer and the flame won't light. Could this be a bad valve?
check gas pressure if ok possible gas valve bad have someone check both sides of valve with menometer
May 18, 2018 | Admiral Dryers
Nov 25, 2012 | Dryers
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Igniter working, can smell gas, but gas not getting to burner
Gas valve is not working. Replace
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
