Question about Kenmore HE5 Electric Dryer
Why won't my dryer turn on?
The lights work on the control panel, but the dryer will not turn on
  • Kenmore Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Posted on Apr 13, 2015
3 Suggested Answers
SOURCE: dryer
i have had that seam problem 2 times, i had two change te bord 8546219 the 2 times , i don´t know way these hapens
Posted on Jun 28, 2008
SearsTechToo
  • 261 Answers
SOURCE: control panel does not work
This is a process so right down everything, remove the 3 screws on the rear of the dryer for the top panel. Be sure you unplug the machine first before attempting this as high voltage is present. The front user panel is clipped to the chassis and we need to check two items. First the wire harness from the motor control unit to the panel and how well is the board attached to the panel. Look inside and you will see catchs bottom and top, with carefull lifting up and out the top loosens and then the bottom. We want to check the assembly and how well the wires are attached. If all looks sound unplug the board from the motor control unit and replug the unit. Now reattach to the chassis, make sure all is clear of the top and plug it in. Try to power up the unit, if not the panel is dead.
From when you mentioned the dryer light worked I know power is there for the board but I will not say off hand just buy a board, test always look for loose panels and wires then we go broke buying the part. Last is the machine new? If less than a year call sears, 1800for my home and have them fix it!
Posted on Sep 12, 2008
Control panel won"t work
sounds like either bad control board,bad user inner face or bad door switch
Jul 29, 2015 | Dryers
Whirlpool duet dryer, no lights on panel...
check both breakers one may be bad if its a220dryer
Jul 24, 2013 | Dryers
I have a kenmore 90 series elec dryer. Model # 110.64924200. When I turn it on it won't start, however I can hear it click. Like a car turning over but won't fire. Any suggestions? Already cha
the start relay in the control panel is bad,the relays coil is moving this is the click you hear,but the main contacts in the relay are bad there are 4 wires to it 2 for the start switch and 2 for the main contacts
Oct 24, 2012 | Kenmore Dryers
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
Dryer won't turn on - digital panel is on
Check the fuse. It is mounted on the right hand side of the control panel:
This fuse trips when that element gets too hot. Look for air restriction or a bad blower wheel.
Older dryer from monkeywards is like yours inside:
Aug 15, 2012 | Crosley CDE6000 Electric Dryer
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Feb 22, 2008 | Kenmore 82822 Electric Dryer
Kenmore HE5 Electric Dryer Logo
215 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
