Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher stopped working mid-cycle
Stopped working no lights show when you push the buttons. Tested Thermal Fuse, Door switch all seem fine. Could it be the main control board? Can that be tested?
    Problem Solver:
  • 6 Answers
Make sure you have power to the unit. Check the circuit breaker.
Posted on May 15, 2014
  • 1314 Answers
SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Posted on Jan 01, 2008
  • 9 Answers
SOURCE: Lights are on, but wont start
The water pump can hum and still have a defective coil.
Posted on Aug 31, 2008
  • 1894 Answers
SOURCE: Kitchenaid Dishwasher thermal fuse keeps blowing
if your fuse is blowing often i would suggest you to move your washer to a different place and try a different plug point.
there may be some fault with your power.
try to sort it out step by step.
thank you
Posted on Sep 17, 2008
  • 128 Answers
SOURCE: My dishwasher simply won't start
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve either?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Do you have water in the bottom of the machine?
Power is there, lights are one, seems to want to work. Water will come in but will not drain.
A small amount around the drain is normal for some machines. This is held to keep the pump primed in some units. However it should not fill the bottom of the unit. You know what it normally looked like so it if is full then you probably have a jammed float valve as above or a clog in the drain.
Drain clog.
Remove the cover from the drain in the bottom of the dishwasher. They usually lift out or have a few screws holding them down. Simple to figure out just take your time and try not to force anything. Look for a clog and clear if necessary.
Your drain can run either direct to the drain under the sink or to the disposal unit if you have one. The drain can clog at either point.
Check by disconnecting the drain line from the dishwasher where if connects to the sink or disposal unit. Look for a clog and clear if necessary.
Water exits the machine via the drain pump. If it is not operating the machine will not drain. It will fill usually to the point where the float valve lifts and does its job by stopping the machine before if floods your house.
If you have water in the machine to the point the float valve is lifted then drain it out first.
Your machine should be running now. Lights will come on and it will run again to the point where if fills with water and trips the float valve again. If so then check the pump and timer (see also timer below).
Remove the units as per below.
If your pump is belt driven check he belt (very few have belts).
If direct drive switch the unit on and let if run to the drain cycle. If the pump does not come on check for voltage at the pump during the drain cycle. If you have voltage replace the pump. If not it is the timer that is faulty (see below).
OK now your are getting to some deeper issues. Not necessarily hard but only go here if the simple things are OK.
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Adrian
Posted on May 03, 2010
goldenglove1
  • 144 Answers
SOURCE: I have a KitchenAid Whisper Quiet Dishwasher. Has
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
Posted on Aug 07, 2010
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
I have a Kenmore Ultra 665.13593K600 that stopped working mid cycle. There are no lights and we have checked electrical and fuse. I am guessing it is the thermal fuse. Does this sound right? How do I...
Yes, could be thermal fuse or door switch, sounds like to me. Both of these parts can be tested by removing inner door panel and then lifting up black plastic cover of the control assembly. Use OHM meter to check for continuity on them.
Apr 09, 2014 | Dishwashers
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Dryer stopped in mid cycle (Kenmore)
Check the door switch. You should hear a click when you push and release it. If no click, replace the switch with this part.
If the switch is good, then the thermal fuse has gone out. Here is a link to that part.
Here is a video to show you how to replace the door switch.
Here is a video tho show you how to replace the thermal fuse.
Oct 16, 2012 | Kenmore Dryers
My Estate by Whirlpool dryer stopped working on 2nd load of day. Push start button doesn't do anything. Power is fine to dryer. Is there an in-line fuse or something that would have been tripped...
Yes indeed the dryer has a thermal fuse that not only could go out between cycles it could also mid cycle and leave ya with a partially dry load and a dead dryer, that is one of two parts that could be your trouble the other is the door switch, open the door and see if their is a little finger on the top right corner of the front panel inside of the door area, if not it has snapped of and the switch needs to be replaced,if its intact the thermal fuse is the problem
I have included links for youtube videos showing you how to replace the thermal fuse and the door switch
http://youtu.be/aUQQJAxkZ0g thermal fuse video
http://youtu.be/gWQhuQXa6d0 door switch video
Jul 26, 2011 | Dryers
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
I have a kenmore dishwasher and it stopped in the middle of a cycle and water is in the bottom. No response from the dishwasher, plug is ok and not tripped. Is there a reset button or not?
When the dishwasher stops in mid cycle and there is no console lights illuminated, then more times than not the thermal fuse has gone out. The thermal fuse is located on the power supply board which is located inside of the console. you must remove the console in order to gain access to the power supply board. the thermal fuse is white and has to wires connected to it. a black wire and a black wire w/white stripe. disconnect the power at the panel box first, before you start. you then remove the old fuse, by "plucking it up" w/ a small flat head screw driver. then you remove the two wires connected to the fuse and place the new fuse in the spot ot the old fuse and place the wires on the new fuse. any order of placement will work. There is a fuse kit that will handle the electrical surges that may have cause the fuse burn out in the first place.
Apr 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
222 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
