Question about Craftsman Garden
Why does my blade drive belt on my riding mower not stay tight
I have an older craftsman mower that I got used. Every year when I take it out of storage the drive belt for the blades is loose
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
You likely have a bearing going bad causing the belt to slip and wear out, or you are not getting the adjustment tight enough. (most use springs these days)
Posted on May 15, 2014
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Posted on Apr 06, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
May 07, 2014 | Garden
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower doesn't cut going downhill
Sounds like a loose belt check the tension spring if they ok check and see if belt is strectched
Dec 19, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
53 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
