Question about Dishwashers
GE dishwasher. gld4500r00bb Buttons do not seem to work and the dishwasher does not come on. I have check the power cord and it is plugged in and the outlet does work. Any thoughts?
    Problem Solver:
  • 6 Answers
Check the plug. Sometimes the male prong gets bent a little and does not actually make contact in the wall. If that doesn't work make sure that wall plug actually works by plugging in a small lamp to see if it works. Check the houses circuit breaker.
Posted on May 15, 2014
  • 93 Answers
SOURCE: I have no power on
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Posted on Jul 26, 2008
SOURCE: Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
Posted on Jul 05, 2008
peping
  • 99 Answers
SOURCE: There is no power going
check the transformer from primary winding to secondary,maybe ist already defective.check the voltage in the secondary,check the switch .
Posted on Mar 13, 2008
aborcass
  • 2651 Answers
SOURCE: plug at end of power cord for kenmore freestading dishwasher
heres a part number for a power cord 8566201, it costs about $50.. the same cord you can purchase at the big hardware store chains, home depot or Lowes, a heavy duty extension cord, with one end cut off, will be a fine sustitute and probly only $10 tops.. just buy a real thick extension cord
Posted on Dec 19, 2008
  • 132 Answers
SOURCE: No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Posted on Jul 10, 2009
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
I am trying to get a manual for our dishwasher here is the model number GLD4500R00BB AND THE SERIAL NUMBER IS FV791217B thanks for your help
Go to this web page:
http://genet.geappliances.com/DocSearch/Dispatcher
Note that you need Adobe Reader installed on your computer, if the Manual link you choose does not open. Get it here(it's free):
http://get.adobe.com/reader/
Hope this helps. Good luck!
Jul 16, 2011 | GE Dishwashers
Lights wont come on and wont wash
Make sure you have power going to the dishwasher. First check under the sink and see if it is plugged in. I know this because I've cleaned under my sink and pulled the cord. Check the breaker as well. It should be labeled dishwasher/disposal.
Good Luck Please rate me a 4 if this was helpful.
Have a great day!
Dec 10, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
I have a GE Quiet Power 3 that has completly died. I cannot get a light to come on or anything to beep when pressing buttons. I checked the circuit breaker and outlet and they are both working fine. I...
A dead set simply means a cut off of power supply. Open the back cover of your dishwasher . Locate the area where the AC cord is located and look for the plastic fuse holder which is usually installed in one of the AC cord line open it and replace the fuse inside with the same amperage or value.
Nov 22, 2010 | Dishwashers
Just put in this nautilus dishwasher which worked fine in the other house is not working now. Where is the manual restart?
check wiring is the plug in working is check gp outlets are they all reset,check brakers is the cord ok ,were the cord goes to dish washer is it secured?
Aug 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Jul 10, 2009 | Whirlpool Dishwashers
GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher will not start
Check your receptacle where the d.w. is plugged into with a voltage tester if it works then un plug the d.w. and take the bottom front panel off.there is a small box where your power cord connects to..usually it has a 1/4 or 5/16 screw holding it closed.Open the box and check to see if the wire nuts are tight.This is usually where the connection is lost
May 16, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Jul 26, 2008 | GE Dishwashers
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
Owen Barnes
