Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Magnifica ESAM 3500 milk temperature low - DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
Posted on Jun 21, 2014
4 Suggested Answers
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
murdozzz
  • 41 Answers
SOURCE: how to replace Delonghi magnifica
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
Posted on Apr 17, 2011
espressonist
  • 1711 Answers
SOURCE: delonghi magnifica esam 4200 lost bar pressure for frothing milk
The most possible problem is that the machine have build up scale both in boiler and in pipe system. Your are still in good chance to solve it easily since it operates normal by performing a good descaling of the machine. You can buy a very good product posibly from ebay like the Urnex DEZCAL which is an excelent descaler and if you perform a couple of descling procedures in a period of one week your machine will perfom better and better.
Posted on Oct 31, 2012
MAGNIFICA ESAM 3500, no water coming through making the pumping noise but no water. the coffee mill seems to be fully extendend and leaning to the right and won't retract. Please help
Is it the electrical part? Are the lights on?
If the lights are on then it is probably the flow of water. Hard water will stop it from working. Sometimes there is a blockage.
You can try to put CLR or vinegar through the machine. You may even want to find someone with an air compressor. If you blow air from the "out spot" it can clear a blockage. If is difficult to tell without having it on front of me.
Sometimes the heating element can be burnt out or a wire is burnt off. Examine the wiring on the inside for any burnt wires.
Jan 30, 2015 | De'Longhi ESAM3500-N Magnifica Digital...
Changing the Magnifica ESAM 3500 milk temperature
This is preset and cannot be altered.. Do ensure you preheat the milk frother before use.. by activating the "clean" button on the frother jug
May 15, 2014 | DeLonghi ESAM3500 Espresso Machine &...
I have Delonghi ESAM 6900....when using the automatic coffee function when it put the milk in the cup it's not very hot...???? I have put the coffee to extra hot....but still in the cup it's like...
If this ESAM is like the earlier 3500, the water heater element is actually a pair of heater elements in parallel but in the same aluminium moulded unit. Being in parallel they act independently
of each other. If one goes open circuit then not enough heat is supplied to the water. Result is coffee a bit hotter than luke-warm.
The only answer is to buy a new part. You can't replace the single duff element because it's in the moulding.
Aug 26, 2013 | Coffee Makers & Espresso Machines
Delonghi magnifica esam 4200 lost bar pressure for frothing milk
Oct 30, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
User manual required for DeLonghi Magnifica ESAM 4200.s
here is general technical data for the unit
http://www.delonghi.com/uk_en/products/esam-4200s/
and here is the manual!
http://www.filesavr.com/YE9UE5DM5WIBGUV
Hope I helped, thanks for using FixYa!
Aug 08, 2011 | Microwave Ovens
The coffee is not hot enough
See page 19 of the ESAM instruction manual; it tells you how to set the temperature.
Jun 20, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
167 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
