Question about KitchenAid KEMC308 Electric Double Oven
How to install microwave glass on kitchenaid KEMC308K
The glass on my microwave shattered when trying to fix the torsion springs. So, i ordered a new stainless skin+glass and it shattered when i put the handle on. How do i properly install without shattering the glass?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Posted on Dec 14, 2008
SOURCE: Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Posted on Aug 25, 2009
SOURCE: Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
Posted on Jan 09, 2010
Kitchen aid torsion spring
I looked up the parts break down for this model there are 7 different ones your last 2 digits are missing this unit dos not use torsion springs the MW door should have a brown arm riveted to the door that goes into the frame this activates a switch
Feb 18, 2015 | KitchenAid Kitchen Aid 30 In. Stainless...
How do i replace kitchenaid superba microwave torsion spring
This is tricky if not done in correct order real easy to break the plastic door frame I will try an explain best I can there is a vent cover between MW door and oven door remove on the MW bottom frame there is a tab on each side with a small screw remove screws you can now pull MW forward won't move very far now the plastic piece that connects to door look up at bottom remove these 2 screws it will be at an angle I use a small speed wrench with a phillips bit okay all this is loose now open the MW door towards top there are 2 holes inside each is a phillips screw use a skinny screw driver hold the door tight it is spring load the frame part with glass will try to slam forward door should now be free usually only one spring is broken change both they are not the same different part numbers take a picture first before trying to remove you will eventually figure out that you have to put in hole at one end and thread thru to the other end then twist in place to lock now be careful if you slip real easy to break inner glass once you figure all this out put the door back in the exact opposite order starting with the door screws first you will now find out the door has a high spring load i usually mate the door to the frame and secure with tape after door is on then do the 2 screws on bottom of plastic frame do the sequence backwards you will break this piece, best i can do yes a lot work but remember I do this about 3 times a week I suggest you think about paying an appliance repair company to do this reason being that plastic piece i keep harping on is roughly 100.00 to replace which negates most savings by doing it your self hopes this helps good luck
Feb 16, 2015 | Ovens
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Jun 16, 2008 | Ovens
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
KitchenAid KEMC308 Electric Double Oven Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
