Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Error code: 1-2036
Attempting to scan for the first time, I used the home center and received "The scan operation could not be completed" Error code: 1-2036.
  • 71 Answers
go to Kodak easyshare support:
http://www.kodak.com/global/en/service/products/ekn026079.jhtml?CID=go&idhbx=easyshareswsupport
In the box under Find Answers, type the complete error code (without spaces), then click Search. An error code should be like 12x413x1304x
Cheers
Posted on Jun 23, 2009
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
WHAT IS THE PROBLEM WITH SHARP AR-5620 SL WITH ERROR CODE L1
Mirror base feed trouble
The mirror home position (MHPS)
does not turn off though the feed
operation is completed during
mirror initial operation after turning
on the power.
does not turn off during shading
operation.
does not turn on when the mirror
base is returned for the specified
time after copy feed is started and
SPF scanning position shift is
performed.
Jun 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
Hp7310 not scanning when using HP Solution Center. Scanner works well with Microsoft Windows Fax and Scan. I have repeatedly installed HP drivers.
May i know the computer operating system and do you receive any error messages while attempting to scan via Solution center?
May 22, 2011 | HP OfficeJet 7310 All-In-One InkJet...
How do i reset the ckeck engine light ?
The reason the check engine light comes up is due to error codes stored in the jeeps computer memory. get jeep scanned at diagnosis center to get error codes, At diagnosis center you will receive the error code.As per the error code it will detect the exact faulty part in the jeep due to which the problem is occurring.For more help :--- at www.autozone.com its absolutely free to get car scanned.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 27, 2010 | 2005 Jeep Liberty
When opening the kodak home center got an error.
it is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact kodak@ 1800 21 6699 for further issues.
Jul 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 1- 2036
I fixed my error code 1-2036 by going to the "Configure Settings" in the AiO Home Center then selected AiO Printer changed to "Print Quality" to Draft and clicked OK.... Then I was able to Scan with no errors. I think the config settings were corrupted some how and this resaved them properly.
if that doesnt help
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
if both the solutions doesnt help... its time to call kodak
Jul 10, 2009 | Office Equipment & Supplies
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
480 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
