Question about ViewSonic Televison & Video
Viewsonic tv function lock - ViewSonic Televison & Video
My Viewsonic television volume doesn't work. with the remote it switches to the Main Menu and the controls on the tv are unresponsive .
Check whether the 'panel lock' function has been set to 'On'. Refer its user manual for details. If it is set to "On' make it "Off'.
Gopakumar Gopalan Google
Mar 16, 2014 | ViewSonic Televison & Video
My 4.4 dish network remote codes listed for viewsonic hdtv do not work,I have tried:507,551,562,566,575,583,600,752,760,796 ( 606would not program into remote)
Hi there TonyMichael, my name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you and provide you with information that can help program your remote to your television. The codes we have listed for a Viewsonic Tv to be programmed with a 4.4 IR/UHF Pro remote are: 566, 505, and 760.
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at kimberly.escobar@dish.com!
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Oct 11, 2013 | ViewSonic N2630w 26 in. LCD TV
My viewsonic tv will not turn off with the remote or the power button. i have to switch it off at the wall. it is displaying message power lock enable.
Try disabling the lock by pressing and holding [1] (menu) and the down arrow on the front panel for 10 seconds or so. This toggles the power lock on and off for several Viewsonic monitors.
I hope this helps.
Mar 21, 2011 | ViewSonic Televison & Video
Could you please let me know if i can use my viewsonic monitor as a tv if so what cord do i need to get
The monitor does not have a built-in TV tuner and cannot function as a TV unless your computer has a TV tuner. In this case all you need to do is connect the monitor to your computer and start the TV tuner/program in your computer.
Jan 11, 2011 | ViewSonic VX2235wm LCD Monitor
I have a 20inch view sonic LCD TV and it says menu locked can you help
When menu is locked this means the child lock function has been activated on the system. This is usually to stop kids from tampering the remote and adjusting settings. The procedure for doing this differs from unit to unit Refer to your user manual to determine the procedure for unlocking the unit.
Hope this solution has been helpful?
Sep 24, 2010 | ViewSonic N3735W 37 in. LCD TV
I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
Viewsonic power lock
On the tv itself hold down channel up button while holding that press and hold the menu button . this will un lock it
Dec 29, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Dec 19, 2008 | ViewSonic N3735W 37 in. LCD TV
3735w Viewsonic Power lock problem
I had the same issue on my Viewsonic N3752w
The online guide, said I had to press VOL+ and Menu at the same time, but forgot to say
a) it's from the TV buttons NOT the remote!!!
b) you need to keep pressing these 2 until it stop saying "Power unlocking" but Unlocked.
Sep 14, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
24 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
