Question about Refrigerators
I got a uline B198 B ice maker from a business that said was still working. when plugged in, the copper line in back frosts over cold but unit itself inside not cold and doesnt make ice. Someone told me its compressor or capacitor and worthless, but i think they didnt know what they were talking about. What can i do to see what could be problem?
  • 34 Answers
Being the line is cold the comp is working, may be low on freon.
Posted on May 15, 2014
  • 17 Answers
SOURCE: hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Posted on Dec 10, 2007
aborcass
  • 2651 Answers
SOURCE: refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Posted on Nov 16, 2008
lojacksdad
  • 121 Answers
SOURCE: I have a Maytag MTB2156DE refrigerator with an ice
the water line comes from the bottom back of the fridge it sound like you have a blocked line meaning
you have a bad water replace valve and clean out line
Posted on Apr 13, 2009
  • 286 Answers
SOURCE: My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Posted on Jun 11, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Posted on Aug 07, 2009
HELLO I HAVE A ULINE WH95TP IN A BOAT WE HAVE IN FOR REPAIR AND THE ICEMAKER WONT GET COLD WAS WORKING BEFORE ANY THOUGHTS ON WHAT TO CHECK THERE ARE NO SCHAMADICS ON IT THANKS JOHN
Ice makers need refrigerant just like freezers and if it get too low it will quit working and probably burn itself out .call a refrigeration repair person and ask them to check it out .
Jul 30, 2015 | ULINE U Line Marine/rv Ice Makers Wh95tp...
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
My ice maker gets cold but will not make ice
I assume you have a good water supply ti the unit.
An internal switch of thermostat may have failed inside the ice maker head unit.
A good repair shop should be able to fix it.
If the unit is several years old it may be best to replace the icemaker.
Make sure they are factory authorised to fix uline products.
Jan 16, 2010 | U-Line Icemaker
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
Uline icemaker on boat needs service..
first do a good cleaning as the manual describe.
check water supply and if still the problem, check power to cutter grid
should be 9 volts all the time
Oct 02, 2009 | U-Line Uline Origins Series...
My uline BCM45A ice maker is cold but does not make ice
This unit work on the thermostat. When the temperature gets between 10 - 15 degrees it will satisfy the control then turn the compressor off and icemaker will advance. If the control is set too cold then it will never satisfy the control. 1st make sure the thermostat is at the warmest setting. When the compressor cycles off look to see if the icemaker is advancing.If no then replace the control.
Sep 15, 2009 | U-Line Icemaker
Uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
May 26, 2009 | U-Line Icemaker
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Dec 23, 2008 | U-Line Icemaker
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
