Question about DCS 30 Single Wall Oven, 30
Where can I locate bulletin S-DOVB-12-01
I am trying to locate a company bulletin before taking apart the oven control panel to ship it in for repair.
I have a turbo chef tornado 2 (subway) ...my keypad doesn't always work. I had a repair company look at it and he said he thinks it's the control board. His reasoning is that the keypad works most of the...
lets start here before taking anything apart . contact the company and see if the parts they think are needed are still available. If so then you could price then and if you decide it worth that price proceed .
Jan 28, 2015 | Ovens
Oven
We had a 1980's wall type oven that would not control the heat any longer. It had an electronic digital control board , the clock worked fine. To replace the oven new was like $700. We had a Sears repair guy come and he said to use the internet to find a replacement control board. After extensive research using the numbers on the board itself I found a company in Canada that does repairs, (there were a couple of companies offering this service, I can't remember why I picked the Canadian company) they explained that using a new replacement may just give you another board with the same weakness built in. This made sense to me so I took a chance and mailed them the board (shipping to Canada was a bit high) got it back in a couple of weeks, took 5 minutes to re-install and its working great. The repair was just under $140 plus shipping.
Apr 17, 2014 | Ovens
My kenmore builtin wall gas oven is suddenly flashing F7 on the panel and won't stop even after pressing clear off
Hello,Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can separate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, replace the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel.
Thanks
May 31, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Feb 08, 2010 | Thermador Ovens
Kenmore model number 95781000 displays error code E1 F1. Occurred after power outage. Clock & oven do not work. Surface works. From what I'm reading, it's a better decision to buy a new oven than pay...
Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. A fuse 2. Control panel 3. Relay panel. Good luck!!!
Oct 28, 2009 | Kenmore Ovens
E1-f2 display for kenmore oven
Oct 19, 2009 | Ovens
I HAVE A KENMORE DOUBLE WITH FO AND BEEPS HOW DO I
Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Oct 13, 2009 | Kenmore Ovens
F 7 appeared on screen and it is beeping and won't turn off
Error code f7 on Kenmore wall oven 911.41165791
Try this first!
Apr 07, 2009 | Kenmore Ovens
Control panel for Lang Oven Model# EHS-LMOR
I work for a company in the U.S. that supplies repair parts for all commercial kitchen equipment. If you would like to contact me feel free to email me at michael.albertson@3Wire.com
Mar 17, 2008 | Ovens
DCS 30 Single Wall Oven, 30 Logo
132 people viewed this question
Top DCS Ovens Experts
ashburton
ray gallant
Are you a DCS Oven Expert? Answer questions, earn points and help others
