Question about Garden
I have a craftsman 5bsxs.0404ma gas grass trimmer.
The starter rope wont rewind. There is a little bit of tension on it but I cant get it rewind. Please help.
4 Suggested Answers
boscia
  • 163 Answers
SOURCE: starter rope on Troybilt TB575SS
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Posted on Nov 29, 2008
  • 109 Answers
SOURCE: just tried starting my ryobi trimmer and the
if ti didnt retract chances are the spring is broken and will need to be replaced
Posted on Aug 23, 2009
sleprocks
  • 147 Answers
SOURCE: starter rope pulled out and wont retract on
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Posted on Oct 22, 2009
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
My wiper sniper pull cord is broken, how do u change the pull cord?
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Apr 02, 2011 | Garden
How to change the pull cord?
Hi b calm,
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
How do I replace the pull rope on my bl100 trimmer? I know how to install it just not how to get it to rewind.
You are going to need to "preload" the spring in your recoil/starter unit BEFORE you install the pull rope. Turn in in the direction where you feel it becoming tighter. Turn it about 5-7 revolutions. Don't get carried away and make it REAL tight as you will break the spring steel recoil spring. After you have it set, jam it or hold it with vise grips or a screwdriver or with your hands and have someone install the pull rope. Make sure the handle is installed on the end of the pull rope before you begin because when you let the recoil pull your new rope in the handle will stop it. There should be a little bit of tension left on the pull rope once it is drawn in all the way.
Oct 31, 2010 | Garden
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a craftsman blower 358.797130 and the pull core broke .i have taken everything apart but can not get the pully off the seal o ring seems to be stoping it help the manual is no help
Yes, owner operator manuals cover very little in the way of repairs. If you have the unit taken apart down to the starter/recoil unit and you want to replace or rewind the rope on the pulley...it shouldn't have to be removed, unless the starter spring has broken. These units have a cheap starter system that wears easily and causes the problem you have. If you can, preload the spring (before installing the rope ) by turning it several times in the tension direction and then hold it in place and install the rope, Observe how the old rope is looped around the inner core of the starter if you install new rope.
Aug 06, 2010 | Craftsman Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
Oct 22, 2009 | Craftsman Garden
Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
What I do is the following:
Remove the old rope ( what is left of it)
Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
Insert the rope and tie a knot, pull the rope back tight against the pulley
Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
Starter spring should pull rope into housing... good luck
Sep 08, 2009 | Garden
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Jul 31, 2009 | Garden
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
