Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio wont spin all the water of my clothes - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 32 Answers
Check for obstruction in the drain pump, make sure the tub turns freely, bad capacitor.
Posted on May 16, 2014
2 Suggested Answers
mikadot
  • 2113 Answers
SOURCE: my washer will not spin or agitate clothes
Most washing machines work with just one motor... it runs clockwise to run the transmission as an agitator and counterclockwise to run the pump and to turn the whole drum to spin dry.  The belts often look loose but are fine.   Check that the belts are on... if they are then the motor may not be running in reverse.  if that is the case then you need to diagnose whether the motor is the problem or the controller.  Check the centrifugal switch in the motor too.
Posted on Nov 10, 2009
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
UL comes on in spin cycle. I cannot spin water out of clothes
the code is telling you that your load is out of balance, move clothes around and try again or you may have the start of bearings going bad
Aug 19, 2015 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
5d code
5d is suds warning. The motor is being overworked from too much suds caused by improper measurements or detergent or both.
Cabrio service manual is on my service manual page
Run your washer without detergent a few times. Remember this washer uses less water than a normal washer it has 2 pumps. one recirculates a small amount of water over them clothes. You go adding in a regular amount of clothes and that washer fancy electronics gonna have a cow.
Dec 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water wont spin out
pump may have stuff in it slowing your drain down or it could be bad.
Mar 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
