Question about Whirlpool GX5FHDXTS Stainless Steel
How do i force defrost on this fredge
I replaced a something that was on evaporator on right that was open circuit and i just wont to see if i fixed the problem
  • 34 Answers
To check defrost you first need to have an evap coil temp below 32, the thing you replaced was prob the temp sensor for the defrost.
Find the def timer and turn it till it goes into def.
Posted on May 15, 2014
How can I force defrost a jenn aire refrigerator jsd2695kes
Check manual to see if there is a manual technique for activating the defrost timer cycle. If not, and you are in rush, remove back cover of freezer, and after unplugging unit use hair dryer to melt the ice built up on the evaporator.
Nov 26, 2013 | Jenn-Air JSD2695KES Side by Side...
The freezer wont freeze and the back panel is covered in frost
Hi and welcome to FixYa. I am Kelly. Your refrigerator is not defrosting automatically. This can be caused by:
1. Defrost time control
2. Open defrost heating element
3. Evaporator fan motor either not running or running to slow.
4. Wiring
Since you did not include a model number and due to the various defrost controls I can not help you. I really need your make and model number to point you in the right direction or to provide you a source for replacement parts.
In the mean time you can get a 2 - 4 day reprieve by doing a manual defrost. You do a manual defrost by performing the following steps:
1. Unplug the unit
2. Remove freezer contents
3. Place a fan blowing air into the freezer compartment for a little over 2 hours. (Makes a mess... rags and Mop time)
4. After 2 hours wipe out any residual water...
5, Plug in unit
6. Reload freezer.
7. Check temps in 4 - 5 hours.
All this will do is de-ice the evaporator coils. (I.e what the auto-defrosting function is supposed to do.) The automatic defrost circuit will most likely have to be troubleshot to return the unit to normal service.
Thanks for choosing FixYa,
Kelly
Sep 19, 2010 | Kitchen Ranges
My fridge side by side the freezer develop a lot of ice in the back and wont defrost it supposed to defrost by it self but it wont, tried to clean the back and remove all the melted water from the back ,...
Your problem is in the defroster circuit . Most defroster circuits contain only three components. They are : a timer , a heating element , and a temperature sensing cutoff switch.
Your refrigerator defrost timer shuts down normal operation every six to eight hours and goes into the defrost cycle.
Line voltage is applied to the heating element . It heats up and melts the ice on the evaporator. Once the ice is melted, and the evaporator area warms up to a certain temperature, the temperature sensing cut off switch opens up and stops the current flow through the circuit. The timer is a running clock, so to speak , and will eventually deactivate the defrost cycle return the refrigerator to its normal operation .
Normally, the element or sensing switch will be the component to replace. Also, sometimes it can be just a bad connection in the element and sensor wire connectors.
Mar 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a GE GSS22KGMA side by side. Fridge gets warm at the top
I am going to paste part of your text and then reply:
Your text:
Repairman came back and replaced a small round part at the top of the evaporator (resistor??) <
{ That was the termostat}
I just read that the problem could be the defrost thermostat..
He already replaced it.
I hate to say it but is sounds like your in repairman hades.
So far I see 1. a new mother board, 2. new defrost thermostat and 3. new defrost heater element. (other than wiring that is everything in the circuit)
Either one of the 3 NEW parts is bad or...there is a partially broken wire in the circuit.
Hopefully this helps you understand. ( I know it does not fix your uint)
Thanks for using FixYa.
Kelly
P.s your words again:
one would expect this to be remedied.
You got that right!
Feb 11, 2010 | Refrigerators
Second new Whirlpool fredg. that will not stay cold
whirlpool had a bad run of evaporator fan motor (the fan in the freezer section) it is a simple fix and a good service company should pick up on it. since the unit is new have lowes send out a different serice company than the first one mention to them about the air not blowing good to the refrig section and if the fan motor is running fast enough. they should replace the fan motor with part number 4389177 this is a whirlpool part.  Let me know how it turns out. thanks Peyton
BTW whirlpool is one of the best so be patient and let em fix it you wont be sorry...
Mar 14, 2009 | Refrigerators
MAYTAG PLUS, MOD MZD2766GE STOPPED COOLING ON THE RIGHT SIDE,
After they replaced the part did they defrost the unit. there is probably ice build up on the coil behind the service panel in the freezer compartment. If the defrost control was the part replaced you can probably push the refrigerator side light switch in and out 5-6 times and force a defrost. if the unit goes into defrost then all the components are fine and you just need to manually defrost the coil either by off loading all food and leaving the unit off for 4-6 hours with doors open. of offloading freezer side remove rear access cover in freezer exosing evaporator coils and use a hairdryer to defrost the ice accumulation. good luck Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Refrigerator cooling fan freez so not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gf
Dec 27, 2008 | Nokia 3230 Cellular Phone
Whirlpool GX5FHDXTS Stainless Steel Logo
78 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
