Lution graphical installer - Computers & Internet
Where do I get a owners manual for a 1988 Teton 5th wheeler?
Try your spare...if u have one to work out if its the key or the receiver in the car that's faulty...then I suggest you go online to your cars owners forums.....if u have a particular fault it usually follows lots of other people have had the same and usually suggest a so
lution.
Dec 16, 2015 | Cars & Trucks
Tip
How to install Graphics Drivers, Nvidia and AMD Radeon!!!
In order to get the best performance out a device one needs to have the most current/latest drivers installed on your computer system. The latest drivers provide better performance because they enable your operating system to make better use of the device, this therefore means the device operates effectively.<br /> <br /> Today you will be learning to install the latest drivers for your graphics card, so your computer can run at a higher resolutions and give you the best performance available from your graphics card.<br /> <br /> The manufacturers of Graphics Cards are shown below, click the makers name to download the drivers.<br /> <a href="http://www.nvidia.com/Download/index.aspx?lang=en-us"><span>Nvidia</span></a> Graphics Driver for <span>Nvidia</span> made Graphics Cards.<br /> <br /> <a href="http://support.amd.com/us/gpudownload/Pages/index.aspx"><span>AMD</span></a> Graphics Driver for AMD/ATI Radeon made Graphics Cards.<br /> <br /> Select your Graphics Card model and Operating System.<br /> <br /> Download and install.<br /> <br /> Note: Only use the drivers provided for your make and model of graphics card!!!<br /> <br /> Enjoy!<br /> damnor01
on Feb 07, 2011 | Computers & Internet
Not getting full resolution of 1920 x 1080 on acer monitor p226hq - installed on HCL desktop - pentium 4 processor - 256 x 512 RAM suggestions
The 64MB graphics card installed was created at a time where that resolution was only dreamed of. The graphics card is not able to support the modern resoultion of 1920X1080.
One option is to install a newer graphics card or install the latest software called drivers, they may help you achieve HD resolution. Drivers can be found on the manufactures website. Download them and install them on your computer.
Take care!
damnor01
Sep 10, 2011 | Acer (9005210464), (64 MB) Graphic Card
I have an ASUS P8 M 67 - M - EVO with an Intel Core i7 2600 K with an integrated graphics card Intel HD Graphics: Base frequency 850 MHz Maximun dynamic frequency 1350 MHz Features: Dual Display...
hi! nothing to worry!
it's a simple problem solved quickly! follow these steps!
sir! u first need to install graphics driver(nvidia graphics driver)
1. try to find the driver cd/dvd that u got along with ur motherboard( asus p8 m67 dvd) !
2. install nvidia drivers in ur pc!
3.then it ask u to restart and install ur magic bullet!
still wont found driver and error appears! visit www.driversdown.com then search for nvidia drivers.
still unable to found driver download driver genius pro software and install it it scans and show the required graphics software! select that tab and hit download !
that's it! ur problem solved!
Rate or Comment me if u like my solution!
Jul 23, 2011 | Computers & Internet
Its running very slow please help me sir
It's due to your graphic properties You need to upgrade your graphics card.You can install 512MB(512 MB is sufficient) ATI or NVIDIA graphics Or Check whether your graphics supporting software is installed or not You need to install graphics upporting software
Or else(if you your graphics memory shared memory) Check whether shared graphics memory software is installed or not
you need to install shared graphics memory software
Thank you Don't forget to rate
Jan 27, 2011 | EA Sports Cricket 07 for Windows
I have a dell dimension 4400 and the original graphics card thats came with it but yesterday i when too turn on my computer and the screen is not picking up and image from the CPU is there anything i can...
OK, I am curious how are you going to install a new graphics card without installing a new graphics card? "picking up and image from the CPU is there anything i can do to install a new PCI graphics card with out having too install the new graphics card"
You can install a different graphics card in the computer assuming you have an open expansion slot. If the Current Graphics card is actually installed in the AGP slot open the Main CPU unit and remove it then install the new card. If when you started the computer you saw anything on the screen, the DELL logo or Bios setup, the problem most likely is not the graphics card being bad but possibly that the settings in windows some how changed and it is set to something it can't support or the monitor has gone out. If it is the graphics card and it is built onto the motherboard you will have to install the new card and when the computer starts enter the Bios to change the BIOS settings to disable the on board card or it will give you problems with conflicting resources. Most graphics cards use the same resources so two cards in the same computer will conflict with each other and neither will work. I would test with a different monitor before replacing the graphics card.
Dec 13, 2010 | Dell GeForce2 MX, (32 MB) Graphic Card
How to install graphic card my computer\nr
Try to plug the graphic card in daughter card slot of mother board Then start your system, if you are using windows xp, Vista and windows 7 Then may be possible that it will automatically install the driver other wise you can insert the graphick card installation disk in cd/dvd drive and install the driver then reboot the system and it will work fine.
Mar 19, 2010 | Intel XFX GeForce2 MX400 (64 MB) Graphic...
Cant seem to install new graphics card
First uninstall graphic driver from computer.
For that when you power up the computer press F8 key then enter in safe mode.
Then go to device manager.
For get device manager right click on my computer iocn then click on property then hardware->device manager.
Then you can see all driver list uninstall display adapter graphic driver.
Also go to start->control panel->add remove program then select nvidia graphic driver and uninstall it.
Then restart computer.
then download exact driver for your model from below link.Then install in computer.
click here
Click on above link and select your model then download driver for your operating system then install.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 09, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
Graphic card
the graphics card has got nothing to do with the game installation, only when the game is installed will you be able to see if the card is performing correctly, if you have a game that requires the cd to run after installation for pirating reasons, assuming you have it installed use cd1 to play the game.
If you can get the correct resolution for your monitor eg 1024 x 768 then the graphics card is working, you would'nt be able to see your desktop.
Nov 05, 2007 | XFX GeForce FX 5200, Graphic Card
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
