Question about Danby Dehumidifiers
Overflow float Does not turn off when full but overflows all over the floor.
4 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Its an edison model emd40s year 200403 and the
Any float will work. Go to home depot and get a toilet float kit. -Good Luck Ned-
Posted on Sep 16, 2009
SOURCE: When the bucket is full
What you should do is remove the bucket and look for a pressure switch which is most of the time under the bucket and test it by pushing down on it's plunger, if the unit turns off either the switch needs adjusting or is there is a plate above it needs the be bent .
Posted on Jul 28, 2010
  • 884 Answers
SOURCE: DANBY DDR7009 REE dehumidifier "Auto" shut off Malfunction
See previous answer. If new, contact supplier to replace float switch. Are you sure it's not just a fan staying on with the tank out?
Posted on May 15, 2012
Bionaire BDQ24 is overflowing
the float might bot be working see if it moves up and down easy and when you lift it see if you hear a click if you don't the switch is bad
Sep 04, 2014 | Dehumidifiers
May 15, 2012 | Danby Dehumidifiers
Haire model HD308 dehumidifier quit shutting off automatically when full?
usually the float is stuck. remove the resevoir and check the upper inside of the machine for the float. if you can flop it up and down easily, it's the switch attached to it that needs to be replaced.
May 10, 2012 | Haier HD308 Dehumidifier
Does not shut off when bucket full and overflows.
From what you have described, the float valve is the top left rear of the bucket may be stuck in the down position and is not rising when the water level rises to the shut off point. Jiggle the float valve handle to free it up. In addition, the bucket may not be installed properly and is allowing water to leak onto the floor. Be sure that bucket is installed "squarely:" into it's holder from top to bottom. When installed properly, there should be no downward tilt at the bottom of the bucket.
To further assist you, I have included a link to your Owners Manual in case you have misplaced yours. You may download and print this manual for future reference.
http://aic.lgservice.com/gcsc/dwn/main
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | LG LHD65EBL Dehumidifier
When tank is full, it doesn't shut off, and tank overflows
yes jenn when the tank fills it will shut off so that it dosent run all over the floor on many models you can hook a hose on to the tank and find a place to drain itto like a floor drain etc
Apr 09, 2010 | DeLonghi DE500P Dehumidifier
Sep 16, 2009 | Edison 40 Pint Dehumidifier
My LG dehumidifier does not turnoff when full and overflows
make sure the float in the bucket isn't binding on something. The float actually activates a button that you can see when you remove the bucket. pull the bucket out and see if the unit cuts off. Maybe the button is stuck.
Aug 11, 2009 | LG LHD45EL Dehumidifier
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
Bucket overfills to the point of spillage
The float is the main feature that keeps it from overflowing. I have no idea why there would even have to be an adjustable component in the circuit. The float is connected to an On-OFF microswitch and may be tested with the unit set to run.
Remove the bucket and manually push upward on the float. If the unit stops running then the bucket may be misalgned,(Make sure float is on the inside of the bucket and not lodged behind the bucket).
May 26, 2008 | Dehumidifiers
Dehumidifiers Logo
41 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
