Question about Vtech Baby Gear
MAGIC CHEF 4 GAS BURNER OVEN LOCATE MODEL - Vtech Baby Gear
  • 183 Answers
SOURCE: Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Posted on Jul 28, 2007
  • 833 Answers
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
  • 1314 Answers
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
Her do I find the model number on my magic chef electric oven. Red light is on staying on? Burners and ovens are all off, What's or how do I find out what's wrong?
There should be an identification plate or label located somewhere (or hidden somewhere) on your oven that indicates model.
Mar 29, 2018 | Magic Chef Ovens
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
We own a 1973 TravelEze travel trailer with a magic chef lp 4 burner range. The model number is unreadable. It does start with BT22 we think. We would like to order a replacement gas regulator and a m
I think you should have more numbers. there are quite a few other series for this unit. I have posted a site below for your assistance.
http://www.aaarv.net/bt22_series_parts.htm
Please rank if this helped
Apr 27, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Baby Gear Logo
97 people viewed this question
Top Vtech Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Vtech Baby Gear Expert? Answer questions, earn points and help others
