Question about Jaguar 97-99 00 01 02 03 04 05 06 Xk8 R. Blower Motor
Hazard lights wont turn off on a 2003 dodge stratus
What causes the hazard lights on a 2003 dodge stratus to stay on ?
  • Jaguar Master
  • 1,140 Answers
The hazard light switch is broken and stuck in the "on" position. Or a wire came off the switch and is touching the other wire on the switch.
Posted on May 31, 2014
HAZARDS LIGHT AND TURNING SIGNAL
You have a relay besides the fuses which controls both available at auto parts store. It is available at autozone for 28.00 have to order part number lm470
Jun 22, 2016 | 2003 Dodge Stratus
Fuel pump has been changed but it will not start.
Search Results
    Dodge Stratus Questions - Car cranks but wont start ...
    www.cargurus.com > Questions > Dodge > Stratus
    CarGurusJan 2, 2015 - Car cranks but wont start - I have a 97 Dodge stratus i bought just a few days ago. ... just cranks but wont actually start. Its not the battery or ... the relay for the fuel pump as well. What could be ... wont start. 2003 Dodge Stratus.
    Dodge Stratus Questions - 2000 Stratus died and won't start ...
    CarGurusSep 7, 2013 - One day when I went to start my car it started up then as I went to reach ... anything to get it starting but he had thought it was the fuel pump but then it ... Ihave a 4 cyl 2.4l DOHC with 172,000 miles. Changed the oil on Sunday and on Tuesday it died while driving ... 2005 dodge stratus wont crank 1 answer.
    Electronic fuel pump problems and replacement- Chrysler ...
    www.allpar.com/fix/fuelpump.html
    A fuel pump failure will usually set no engine codes and you may get no ... Sometimes the pump will give you warning signs that it is about to go but you may not notice ...times on the tank and turn key to start again and listening for the pump hum. .... been through and you'll feel better later knowing that it has been changed.
    Replaced Fuel Pump, STILL NO START!!!!!!! - DodgeTalk
Feb 08, 2016 | 2003 Dodge Stratus
My running lights and turning signals do not work , but my break light and head lights work in my 2003 dodge stratus. Checked the fuses and light bulbs and were told they were good.
Do you hear the clickin sound that you usualy hear when using turn signal or hazard lights ?
Have you checked the brake light switch that is licated at the end of the braking pedal arm (folow the metal upwards you'll encouter the switch) (use a mulyi meter on the sund mode to check if there is a closed circuit)
Apr 20, 2015 | Dodge Cars & Trucks
My 2003 Dodge Stratus RT 3.0 will crank but will not stay running after I Replaced my sstarter what can cause it to do this?
you may have a bad key check to see if there is a light lit up on the inst cluster showing a key or security if so the key is no good and it will have to be brought to the dealer to repair this problem.
May 17, 2014 | Dodge Stratus Cars & Trucks
Hazard light switch
Renew the hazard light switch .its faulty
Dec 20, 2013 | 2000 Dodge Stratus
The Signal lights come on but they wont flash
may be your relay or combination switch. does the lights flash with the hazards on???. Find the relay in the fuse box that say hazard lights or turn signal
Apr 26, 2010 | 1996 Dodge Stratus
Turn signals and hazards are not working
Look under dash on top of steering column for the hazard relay.
Mar 23, 2009 | 2000 Dodge Stratus
Dodge Stratus electrical problem
your battery cables and battery posts need to be cleaned. or the pattery cables need to be replaced
Feb 24, 2009 | 2003 Dodge Stratus
2003 Dodge Stratus Hazard Light problem
I had the same issue with a 2002 stratus, the problem was the flasher relay. It's located inside the steering column, inside the multiswitch, and its fairly easy to replace. Two screws under the steering column to remove the top cover, then two hex screws to remove the multiswitch, then you can remove the relay which is green, mine was part# 04606478AD. You won't find this exact relay at the local auto parts store, but you can order from mopar parts online, or check the parts dept. at your local dealer. I called a local dealer, he didn't have it but was able to find one a few miles away, cost was $30.
Aug 23, 2008 | 2003 Dodge Stratus
Jaguar 97-99 00 01 02 03 04 05 06 Xk8 R. Blower Motor Logo
83 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
