Question about Pepsi Cola VTG Glass & Wood Bubblegum Gumball Candy Peanut Tabletop Dispenser
I have a Pepsi Vending machine model # LC (ILL) 90 9 and I want to find out how I can unlock all the bottle holders so I can remove the bottles with out having to put any money in?
How do I unlock the dispensing locks that hold the bottles in?
Howe do i fix ricoh 2060 code sc342?
there are more possible solutions and cause of this error. First of all the sc code and the sign for no toner are connected. The sc code mean that is there is no toner in the developer hopper. First of all if this code appeared after you replaced the developer, you will need did you connected the two connectors that connect the developer unit with the machine, and also check do the developer unit is properly inserted into the machine. But if this problem ocured before you replaced the developer, than the problem is with the toner holder. Open the front door and check the white hook that pulls out the toner bottle cap when the bottle is home position. This white hook is located on the back of the toner bottle holder. you will notice it when you pull the bottle from 90 degrees angle into home position how it slides on the metal rail located next to the toner bottle holder on the right corner of the machine. If it is broken or out of position than that is the problem. If this part is ok that open the front door and put something like a screwdriver in the upper taster that detects do the front door is closed its located above the red main switch, you will notice a hole with a bronze colored plate inside. The other switch is located on the front right bottom corner next to the third paper tray, you will notice a hole in the olive-brown color plastic. When you will insert something into this two holes the machine will think that the front door is closed and it start the toner loading process. While the machine run, with the door open notice do the toner bottle rotates.If does not rotate than the motor that rotate the bottle is not working. If non of this help than tell me and i will tell you other possible solutions.
Mar 06, 2015 | Ricoh Toner for Aficio 1060, 1075, 2051,...
How do I change the setting from soda bottles to cans
You need to post the model of the machine for help with this.
Feb 15, 2015 | Retail Supplies
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Genesis go380
how come my Genesis will dispense two chocolate bars at a time? Is this a setting of some sort?
Aug 13, 2013 | Selectivend Combo Vending Machine for 14...
How to set up pop bottles
You can download the Manual Here:
www.seagamfg.com/vs3800webman.pdf
Oct 16, 2009 | Victory Seaga VS3800 Commercial...
Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Apr 14, 2009 | Canon imageRUNNER 2270 Copier
Error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Jan 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Pepsi Cola VTG Glass & Wood Bubblegum Gumball Candy Peanut Tabletop Dispenser Logo
32 people viewed this question
Top Pepsi Cola Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Pepsi Cola Retail Supply Expert? Answer questions, earn points and help others
