Question about Microsoft Windows 7 Ultimate for PC
80242006 Does anybody know how to fix this error on windows 7? I am getting this error whilst performing windows update.
    Sergeant:
  • 293 Answers
    , type notepad in the Start Search box, and then click notepad in the Programs list.
  2. Copy the following commands, and then paste them into the Notepad window. net stop wuauserv CD %systemroot%\SoftwareDistribution Ren Download Download.old net start wuauserv
  3. On the File menu, click Save As.
  4. In the File name box, type rename.bat, and then click All Files (*.*) in the Save as type box.
  5. Save the Rename.bat file to the desktop.
  6. Right-click the Rename.bat file, and then click Run as administrator.
    If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  7. Try to install the updates again.
Posted on Sep 10, 2014
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: windows updates doesn't work
click start type cmd press enter then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Posted on Sep 28, 2012
Testimonial: "Hi Brian I found another wonderful solution to these sorts of problems. Just download a torrent file that has all the current service packs and updates already included. I knopw it isn't quite legitamate but if you have bought the product and their friggin updates msee things up, why spend hours and weeks sorting out the underlying system when it should function and flow flawlessly. If you've paid, go get a pre-cracked version. It has wiped this problem from reoccurring."
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Tip
Transform your windows xp to windows 7
Features
Seven Transformation Pack will replace many of the resources in Windows Vista/XP/Server 2003. It can change such things as:
Boot screen
Welcome Screen / Logon Screen
New msstyles files (visual styles)
New desktop and file icons
New toolbar icons
Progress Dialogs
Sounds scheme
System Tray icons
New Wallpapers
Some Windows 7's popular features
And much more
Changes in Version 5.0
-Added automate User Account Control deactivation upon checking
-Added changing desktop wallpaper during transformation
-Added completed set of Windows 7 wallpapers
-Added Gavatx's Rainbar in Vista compatibilities exclusion list as there's already Windows Sidebar in Vista
-Fixed bugs that some options are not saved in registry during installation
-Fixed currupt system sounds scheme in Windows Vista after uninstallation
-Fixed logon screen system files modification to not change system font in non-English MUI (Requires uninstall for older version)
-Fixed setup files detection glitches in Windows XP/2003 x64 Edition
-Fixed system files modification critical error for integration with Windows XP/2003 x64 Editions
-Fixed system files modification compatibilities with non-English edition OS
-Fixed Welcome Center not running on startup after installation on x64 operating system
-Fixed x64 system files modification incompatibilities for some systems
-Improved transformation process for faster and better performance (This involves a lot of work in various places and they're all technical stuff)
-Optimized Deferred Launcher's startup sequence and delay time for better resource utilization
-Removed minimum hardware requirements for 3rd-party applications but still keep recommended specifications in list
-Shortened installation sequence UI for smoother process
-Updated 3rd-party applications hardware requirements specifications
-Updated screensaver to Windows 7 logo
-Updated TrueTransparency
'-Core program to version 1.4
'-Optimized blurring interval for better system performance
'-Rebuilt SevenStyle skins based on Seven structure with real reflections
'-x64 application support
-Updated ViGlance to version SE2 build 1276
'-Added Drag shortcut support
'-Added Hyprid Jumplist support
'-Added Shift+Left click opens new instance
'-Fixed 64-bit application compatibilities
'-Fixed multi-monitor compatibilities
'-Fixed UI and code refinements
'-Optimized timer interval and program configuration
'-Updated default skin
-Updated ViStart to version 2.0 build 3738
'-Added blur support (experimental)
'-Added run functionality in searchbox
'-Optimized programs discovery routine with better program support
'-Optimized UI rendering for better performance
-Updated Welcome Center
'-Added back button in ui navigation control
'-Added system files repair list in repair page and Repair alert with red text
'-Fixed icon and text UI placement
'-Removed using system files from backup source in uninstallation
'-Reworked Removal UI with installed components verification to ensure safety of uninstallation
'-Updated backup files status indicator to available/not available (no need for overwritten check)
'-Windows 7's additional user pictures and wallpapers will no longer be removed (few MBs being too insignificant for TB storage)
-Updated UXTheme patching engine to deepxw's universal theme patcher
Screenshots---
Download it from here---
http://hifkool.blogspot.com/2011/03/new-transform-your-windows-xp-to.html
It works perfectly and tested by me...
For more softwares and antiviruses go here
on Mar 28, 2011 | Computers & Internet
How to fix windows error code 80070003 manually without having to buy a program to fix
http://windows.microsoft.com/en-us/windows/windows-update-error-80070003#1TC=windows-7
Aug 28, 2015 | Computers & Internet
My laptop R18+ is not opening the massage is system registry file is missing or corrupt status 0xc000014c,,what is the problem with my laptop?
Their are few reasons behined this Stop error. It might be due to hardware problem or windows is corrupted. WebRepOverall ratingThis site has no rating(not enough votes)
You need to perform the following steps:
Update the drivers
Fix registry errors
Scan PC with an updated Anti-Virus
Run AntiSpyware
Remove third party programs
Remove junk frm temporary internet folders
If problem still occurs then use system utility tool Reginout to fix this error.
Dec 04, 2012 | Samsung R18 R20 R25 R455 R458 R457 R466...
Packard bell Packard Bell BV EASYNOTE PB62Q01126 AUDIO OUPUT DRIVER UPDATE windows 7
If you are facing the problem with windows update then perform the following tasks before updating:::
>> Scan your computer with an antivirus >> Apply De-fragmentation on your system>> Delete all temporary files>> Run disc clean up>> Fix registry errors.>> Use a system utility tool like Reginout for an instant fix.
Apr 08, 2012 | Microsoft Windows 7 Home Premium for PC
Hi I was trying to do a new install of windows 7 on my laptop.Kepp getting error code 0x80070057. I have no operating system on the hard drive what can I do
Hi, If you get the error:-0x80070057 after installing windows then please perform the below steps:- The first thing that you need to do is to scan the computer. Next, you should perform a registry scan as most windows computers have a registry problem from time to time. However if you get this message during the installation process make sure that when installing the Windows on the computer you have the internet cable unplugged since this error corresponds to Windows update taking place when trying to connect to the Windows website.Once you perform the Windows installation this way you would be able to succeed with the installation. Thank you for your time and best wishes for your effort.
Jan 11, 2011 | Acer Computers & Internet
Stuck in the update loop with error 8002f1f9
I had the same problem... Just fixed it today..
Just before I had the update loop problem, my bluetooth on the PS3 went. I could only use the controller whilst connected to the USB port.
I replaced the bluetooth/wifi board
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
Microsoft Windows 7 Ultimate for PC Logo
89 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
