Question about Hayward Pool & Spa
I have a pentair purex 400 spa heater and it would squeal and black smoke would come from exhaust when on and now it has service light on and won't ignite
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hayward Master
  • 1,448 Answers
Sounds like poor gas pressure check gas pressure sounds like it sooted up and ruined itself
Posted on May 26, 2014
5 Suggested Answers
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
SOURCE: purex triton powermax 400-
This is usually either the Thermal Overload Cutoff (an inline fuse to prevent overheating) which costs $13.50 through poolcenter.com, or it is that you are not getting enough water pressure through the heater. There are sensors that will shut down the heater if there is not enough water flow. Is your filter clean so enough pressure/flow is happening?
Posted on May 02, 2010
  • 990 Answers
SOURCE: heater cycles on / off
This could be a water flo problem. you need to chech to be sure your by-pass valve is closed down enough to force water threw heater, There is a internal by-pass that could be a problem also, or a bad pressure switch. If the by-pass isn't the problem then you should check these also.
Posted on Jul 26, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a Pentair Pueex
I am not real familiar with this brand of heater. But they are all pretty standard. You will have either a pilot light or and electronic igniter. I would start by checking to make sure that the pilot light is lit. If it will not stay lit then you will have to replace the thermal couple that the pilot lights heats. If you have a electronic igniter, then make sure it is sparking properly. If it is not sparking the heater will not light. That should give you a place to start.
Posted on Dec 14, 2010
Purex triton minimax plus 400
You can call Pentair or go to their website: www.pentairpool.com
Then click on the "Find a Pentair Dealer Near You"
I saw about a dozen or so heater service centers in the Dallas area.
Oct 30, 2013 | Pool & Spa
Where is the pilot light on the minimax pool heater 400
down under by front by burn tubes follow small silver tube from gas valve has red and white wires to gas valve take picture before removing if too late see front panel
Jun 02, 2012 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Purex Triton MiniMax Plus 400 power light is not turning on nor is unit. Checked for power going to unit and no fuses appear to be blown. Thoughts on what might be the issue? Thanks, Dan
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
Aug 11, 2011 | Pentair Minimax NT Heater
I just cleaned my jets on my purex mini max plus 400 heater. It is heating great now but has black smoke coming from the top. I think it is rich and is getting too much gas. Is there an adjustment or do i...
First have you always had this connected to propane? There are different models for natural gas and for propane.If you connect a natural gas to propane the "jets" are way too big for propane. How did you clean the jets? IF you "drilled" them out they may be too large now. If you have adjusted the gas regulator, decrease gas pressure. I believe this unit has a combustion blower, be sure it is debris free on inlet and in fan, check for leaves. Make sure black smoke is not coming from debris built up inside of heater. Here is a link to a location for the complete manual for your heater: http://lawnandgarden.manualsonline.com/manuals/mfg/pentair_pool_products/400k_btu_hr.html
Jul 05, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pool & Spa Logo
113 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
