Question about Amana Heating & Cooling
Why wont it turn on amana distinctions airconditioner
Amana ditinctions AC unit will not come on? breakers are on - switch is on - stat is on air filter on Amana furnace is good nothing
2 Suggested Answers
  • 58 Answers
SOURCE: Airconditioner wont come on
you need to start with a volt meter. check the power first at the disconect then follow them wires inside the unit to the contactor check them were they connect on the contactor. then check them on the other side of the contactor. it there is no power there find your transformer check and make sure you got 24 volts if not you need a transformer or maybe just a fuse. does your indoor fan run? compressor and outdoor fan will usually run together. look at your wiring diagram and check voltages at each control device. if your indoor fan runs push in the contactor and see if the compressor comes on use a stick so you dont get shocked. So to sum things up if nothing works problem is probably transformer or tstat or main power. If compressor and outdoor fan don't work could be contactor or capacitor if one of outdoor parts runs but not the other then that individual motor could be devective. but it could also be out on a control such as low pressure switch (low freon)
Posted on Jul 01, 2009
AC chronotherm IV plus thermostat has no display and AC has gone off and will not come back on.
Either the 5 amp fuse is blown on the indoor unit, transformer is bad or float switch is tripped.
May 28, 2017 | Amana Heating & Cooling
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Compressor will not stop running
There has to be a stat or switch or controller of some kind on the rv. I would check that first. If you have a battery operated stat then try changing the batts, otherwise it could be the contactor on the unit or a bad stat.
Apr 26, 2012 | Dometic Rooftop RV Air Conditioner
Amana air conditioner wont turn on. not even fan. has power as we checking the circuit breaker. suggestions?
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 26, 2011 | Heating & Cooling
My Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Dec 05, 2009 | Heating & Cooling
I have a SanSung AirConditioner at a Tower site. I need to fine out a way to make this airconditioner come on when the power comes back on with out sending someone on site to turn it on.
simplest way is to rewire unit and add a refridgeration type stat to a 115v ac coil contactor or relay toturn compressor on and off and hook up fan on 1 speed hope this helps
Jun 17, 2009 | Samsung AW0693L Air Conditioner
Does the indoor blower come on? If not you might have a low voltage problem in your thermostat circuit or blown breaker or fuse for your furnace which energizes the contactor outdoors. If indoor blower runs check if their are any fuses in your outdoor disconnect.
Apr 30, 2009 | Heating & Cooling
Amana Package heat pump wont turn off
i can help with this. call 1-888-855-9987. The problem is on the board.
Aug 12, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
20 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
