Question about Craftsman 20 Hp 42" Deck Lawn Tractor
How do I tighten the deck belt on a Husqvarna YTH2348?
I have a 2010 Husqvarna YTH2348 lawn tractor. It started running rough last fall, so I took it in and they cleaned the carb, changed oil, checked belts, tune up, etc. it was running great, a loud "whoosh" sound when engaging the blade and cut really well. After a few mowings and aerating my yard, I noticed what sounded like slack in the belt. Then the deck belt popped off after disengaging the blades after mowing the front lawn. I just replaced the belt and no change. Any ideas? Thanks!
  • Craftsman Master
  • 2,478 Answers
Is your spring hooked up.
Posted on May 15, 2014
  • Joe Fristoe
    Joe Fristoe May 15, 2014
    Yes, the spring is attached and the tension arm is in place.
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 148 Answers
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Posted on Jul 27, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I have a Craftsman LT2000 tractor and I've had a
the pulley that the disingage spring is hooked to sounds like its freezing up it may need some oil put on it to make it slide easier
Posted on Oct 26, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Craftsman GT 5000 Garden Tractor, 25 HP,
Depending on your engine.. Briggs and Stratton or Kohler there are 2 different seat switches that are used to power the PTO clutch. The seat switch can cause the PTO clutch to disengage anytime there is not at least 70 lbs in the seat.
The PTO drive wiring has a 30 amp fuse in it. If by chance a stick went through the belt and tore off the wires at the PTO clutch (Common failure) even after you repair the broken wire you still need to replace the fuse.
Check the PTO clearance gap. It should be 0.012 dis-engaged. Any other value and the clutch will not work correctly. Adjust the clutch if necessary.
There is a 2 pin Pigtail just off of the PTO Clutch that you need to check for voltage at the connector. Probe the back of the wires if you can and your looking for 12V DC under the following conditions.
BRAKE ON or tied down
KEY ON
SEAT (Briggs and Stratton engine only) Someone needs to be sitting on the seat.
Then Pull the PTO Switch out. You should hear the PTO Clutch CLICK. If you hear the click there is no need to check voltage. The PTO switch is a multi function switch and it is quite possible the PTO switch failed. I doubt that the PTO Clutch has failed as they normally give you some kind of noisy indication that they are failing and don't fail straight away.
So.. In short
Check PTO Switch (Red wires) to usually red or brown thru the switch
Check 30 amp fuse
Check PTO clutch wires near PTO clutch (They get torn from something traveling through the pulley)
Check PTO clutch clearance at 0.012
Check Brake switch for an audible click as you depress it some distance No click.. possible bad switch
Listen for Seat switch Click as you slowly add weight to the seat. No Click or any click and it can still be suspect due to the Briggs and Stratton installed engine ones have more than one function.. Ignition and PTO clutch power.
The actual wiring diagram is on page 35 of the owners manal that can be found here:
http://www.managemylife.com/mmh/owner_manuals/27245/CRAFTSMAN-Lawn,-Tractor-L9910386?brand_name_search=917273023
Lastly... check each of the mower deck blade bearings. A seized bearing can cause PTO problems.
Hopefully you have enough information to solve the mystery. If not just respond here and I will help you.
Thanks for choosing FixYa.
Kelly
Posted on Oct 07, 2010
Testimonial: "Kelly - Your troubleshooting info helped me determine the PTO switch, mower belt and 30 Amp fuse were good. Solution: New battery fixed it. Thx! - Tom"
No fuel flow from tank to engine on Husqvarna YTH2348
Try changing the fuel line as there has been a few cases where the inter liner of the fuel line on the carb complaint systems collapsing causing this problem.
Also check fuel cap rubber seal if it has deteriorated and parts of it may be blocking fuel flow from the tank. An additional thing to try is leave the ful cap loose to if it is venting problem.
Jun 21, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Had work done last winter because drive belt kept coming off...Found the two bolts that hold transaxle in place kept falling out, also the plates that bolt over axles were worn/broken...have items rep
I own this model, I have not experienced this issue,something is causing excessive vibration to cause this issue ....a bad belt,misalignment or a sheave that is bent !
Sep 23, 2014 | Husqvarna Lawn Tractor  25 HP 54in Deck...
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
If this is a briggs and stratton they have a fuel pump on the front of the carb and ethanol plays havoc with the diaphrams in the fuel pump. I have to overhaul the fuel pump each year. Before you try anything else try "mechanic in a bottle" first. It is available at home depot, lowes, tractor supply etc. Just follow directions on the bottle and often it will clean out the varnish deposits in the pump and the carb both. Hope that helps.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower cranks wont start prim carb and runs
check the solenoid on the bottom of the carb they stick and shut fuel off threw the carb
Apr 28, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The drive belt keeps falling off, why? aand how do I fix it SHERRY
if the drive belt continues to come off it could be that the drive belt spring tensioner has failed.
Aug 25, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Light came on for oil change - oil is changed is there a 'switch' to get it back to be able to start?
Hi, the oil change light will go off in two hours running time. It does not stop the mower from starting. If your mower will not start you have an unrelated problem. Hope this helps, regards Phil
Jun 24, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Husqvarna lawn tractor deck will not engage Tractor runs fine
First check the belt.Make sure it is tight when the lever is engaged,and the engine is off.Make sure the belt is on all pulleys,and inspect for frays in the belt.If the belt is ok then,run your hand under the fender around the area of the lever.Make sure there is no debris blocking the lever from fully engaging.If that is good.Next inspect the linkage between the lever`s handle and the deck.Again make sure there is no debris and all connections are snug.
May 16, 2011 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
412 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
