Question about Sony ICF-C212 Clock Radio
WHEN alarm is set but the indicator light won't light up and the alarm does not go off?
When I set the alarm, the little indicator lights for buzzer or radio will not light up and therefor the alarm is not activated and does not go off, what am I doing wrong? Or why is the alarm not working?
  • JoAnn Ham
    JoAnn Ham May 17, 2014
    I figured it out....it's just a dumb clock radio
I have a Timex T311 clock radio. How do I shut off alarm and radio everyday. As I no longer need to wake in the am.
On the Timex T311, to disable the radio alarm, press the Radio Alarm button once. The Radio Alarm Indicator light should go out and the radio alarm won't sound. If you press the Radio Alarm button once more, the radio alarm will toggle to on and that indicator light will come on. Similarly, press the Buzzer Alarm button once to enable the buzzer alarm and press it again to disable the alarm.
See page 9 of the manual to see the directions to toggle these alarms on and off. The manual is available from Timex Audio on the product page: https://timexaudio.com/support/product/T311/ . The direct link to the manual is https://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf .
I hope this helps.
Nov 15, 2017 | Timex Audio Players & Recorders
How do set the wake up alarm on am/fm digital clock radio model ONB14AV201
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently set radio station. The alarm buzzer or radio indicator will light up.
Jan 21, 2015 | Audio Players & Recorders
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Ozaki imini (cute)
This is easy, hold down "mode" until the alarm time flashes, then press "mode" again, it will cycle through a menu, there is an "on" option to turn on the ipod at a certain time, you select "on" then press mode again, it will cycle to the next menu, set the time you want the ipod to turn on, press menu again, then you can select the "ipod off" time, I keep that option off as I want the ipod to stay on until I turn it off. Now you have set the ipod to turn on at whatever time you want. Turn off that terrible buzzer alarm. The confusing thing is the imini has to different alarm modes, not one alarm mode with two alarm sound options like most everything else.
Jan 26, 2009 | Audio Players & Recorders
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Turn the alarm off
Just push the button marked radio, sound or buzzer on the front right side of the face or panel - when you see radio, sound or buzzer light up on the screen alarm is on (to whichever you set it - radio sound or buzzer- if you push the button again it will go off. Took me a while to figure that one out too!
Oct 11, 2008 | Timex T309TT Clock Radio
Sony ICF-C212 Clock Radio Logo
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
