Question about Black and Decker USA black & decker grass hog® replacement spool 065"
Trimmer wrapped around shaft
String got caught under spool and wrapped around shaft so it won't spin. I was able to get most of string out, but can't reach rest unless I detach spool head. How to do that?
    Sergeant:
  • 340 Answers
Deborah there should be a little hole just towards the bottom of the spool head where you could fit a small metal rod in. If you can locate it push something small in like a 2 inch nail and turn the spool head slowly by hand until it locks up. The head should then undo . It will undo anti clockwise.
Posted on May 18, 2014
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
String wrapped around shaft
i would remove the trimmer head then cut the string off
Aug 08, 2012 | Garden
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
WEEDS ARE WRAPPING AROUND THE MOTOR SHAFT ABOVE THE TRIMMER LINE DISPENSER CAUSING THE MOTOR TO SHUT DOWN AFTER 30 SECONDS OF RUN TIME DUE TO INCREASED FRICTION ON THE SHAFT
That is a common problem with many trimmers... not much you can do about it...except be more carefull and go slower so the weeds fall down before getting caught by the line and getting twisted around the shaft...
heatman101
May 11, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
String caught in spool. Need to remove spool but
look for a notch in trimmer head above spool close to shaft and corrosponding notch in shaft.
these notches are for holding shaft in place with a screwdriver so you can losen the tap cap screw...
speakin of screwdrivers anyone see where my vodka went?? lol
Jul 31, 2009 | Garden
String is wrapped around area under spool housing
Do not get spool housing off even you got problem such as wrapped string, please go to service center for help.
Sep 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
Black and Decker USA black & decker grass hog&reg replacement spool 065" Logo
134 people viewed this question
Top Black and Decker USA Garden Experts
James
richie46
Ruth summersides
Are you a Black and Decker USA Garden Expert? Answer questions, earn points and help others
