Question about X-Treme XB-610 Elite Electric Bicycle 600 Watts-20 AMP Battery System
Why does my tire wooble after changing tire and tube?
Tire has slight wooble at about 15 to 20 mph
  • Dennis Anderson
    Dennis Anderson May 17, 2014
    Is there a solution to my problem?
  • 16,037 Answers
This could be a bad tire or it could be that the bead did not seat in the rim.
Posted on May 14, 2014
2003 trailblazer back tires woobles tires drivers side back tire bald on inside
Your tires are bad , replace them . An have a wheel alignment done .
Jan 21, 2017 | Cars & Trucks
1994 silverado shakes slightly between 25-30 mph
Check your tires. you could have broken steel belts in a tire.
Feb 28, 2015 | Cars & Trucks
Vibration on right front tire at 70 mph to 75 mph
Well......
- tire is out of balance or out of round
- wheel rim has taken an impact and is slightly deformed
- front shock absorber is faulty and is allowing the wheel to tramp
- front suspension joint is worn or loosened
Take it to a suspension shop and have these things checked
Jan 15, 2014 | 2000 Chrysler LHS
Ride on mower tube
No I never inflate them when fitting them. But I do make sure the inside of rim and tires are free of burrs, etc. Then when inflating I slightly press the side of tire to let tube inflate and to let air trapped between tube and tire escape. Hope this helps!
Jul 22, 2013 | Garden
I have a buick lesabre 2000 nd my tire went flat the check tire pressure light came out.. So i went to buy a new tire nd change it. But the light is still there.. I tried to reset it how it says on the...
SWITCH IGNITION ON, REPEATEDLY PRESS GAGE INFO BUTTON UNTIL THE MESSAGE TIRE PRESSURE IS DISPLAYED IN THE MULTIFUNCTION DISPLAY, PRESS AND HOLD RESET BUTTON UNTIL THE MESSAGE TIRE PRESSURE RESET IS IN THE DISPLAYED IN THE MULTIFUNCTION DISPLAY,RELEASE THE RESET BUTTON THE MESSAGE TIRE PRESSURE NORMAL WILL BE DISPLAYED IN THE MULTIFUNCTION DISPLAY, AFTER RESETTING TPMS THE VECHICLE REQUIRE UP TO 30 MINUTES OF STRAIGHT LINE SMOOTH ROAD DRIVING IN EACH OF THE 3 SPEED RANGES 15 - 40 MPH - 40 - 70 MPH - 70 - 90 MPH. MAKE SURE ALL 4 TIRES HAS THE RIGHT AIR PRESSURE BEFORE RESETTING TIRE PRESSURE LIGHT.OR LIGHT WILL NOT TURN OFF IF ONE TIRE IS LOW.
Jul 16, 2011 | 2000 Buick LeSabre
No tire or tube on rim. where do I start for trying to put the new tube and tire on?
its somewhat hard to explain in words
check this video out
http://www.youtube.com/watch?v=u7KJK_rl9cU
also most bike stores will probably help you out for free
Nov 09, 2010 | Cycling
Vibration in steering at highway speeds?
vibration at highway speeds is normally a tire balance issue. take it to a tire shop and have them inspect and balance the tires.
Feb 21, 2010 | 2004 Cadillac Seville
FACTORY TIRES NOT WORKING
Make sure the rims are seating properly and you could have tread seperation on the original tires or tire. Might have been why and when they changed wverything.. Tire and wheel package cheaper than 4 new tires
Aug 26, 2009 | 1999 Chrysler 300M
Has a slight wobble at low speed?
you need to jack it up and spin 1 tire at a time, use a run out guage on the tires and wheels.a high speed 60 to 65 mph is from wheel balance. low speed is a bent wheel or a bad tire. belt separation
Aug 04, 2009 | 1990 Nissan Pulsar
X-Treme XB-610 Elite Electric Bicycle 600 Watts-20 AMP Battery System Logo
62 people viewed this question
Top X Treme Scooters Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a X Treme Scooters Vehicle Part and Accessory Expert? Answer questions, earn points and help others
