Question about Miller Welding Tools
Find serial number on yamaha Grizzly four wheeler 2007
I need to find the vin number for a 2007 Yamaha grizzly four wheeler. Need the vin number to get some parts ordered for it.
  • dan lincoln May 14, 2014
    Hi Lisa Lunning, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? most bikes id their frames at the front steering headset tube of the frame. i wish i had more specific info for you. inspect your frame is the partial answer i have available
    may i offer this idea, when you call to get parts the parts people may be able to direct you on that machine. or they may have a number to call
  • 65 Answers
SOURCE: 2007 Yamaha grizzly 660 wll run fine, and then
CHECK VALVE CLEARANCES(INTAKES MOSTY) IS IT ONLY HARD TO START AFTER IT HAS BEEN RUNNING(HOT) OR IS IT HARD TO START COLD TOO?
Posted on Apr 30, 2009
ollie reece
  • 1167 Answers
SOURCE: How do you Adjust the idle speed
on the carb there is a screw sticking out with a little spring on it screw it in 1/4 of a turn to take the revs up a tad
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: 2008 Yamaha 660 Grizzly???? Help?
try turning your idle down, i have a 98 grizzly 600 and the other day it was cold so i turned the idle up to start it and wen i put it into gear i would drive itself if ur idle screw is in the same place as mine it should be above the engine beside ur left leg turn it left to turn it down wen ur idle is up ur motor is reved to hi wen going into gear hope my advice helps
Posted on Jul 17, 2009
  • 11 Answers
SOURCE: Need to find serial number on 1997 Timberwolf 250
It should be stamped on the left hand lower frame.
Posted on Feb 06, 2010
suzukiracing
  • 200 Answers
SOURCE: Yamaha Grizzly 600 starter clicks and wont start
A loose conection at the starter or the starter relay is bad.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
2008 Grizzly 450. Starts and idles fine but at about 10 mph why does it start to cut out like a rev limiter?
2011 grizzly 450 reverse rev limiter - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & Transmission
Mar 11, 2012 - 9 posts
This is a discussion on 2011 grizzly 450 reverse rev limiter within the ... is for earlier model years like 2008. thanks for welcoming to the site :) rev limiter - Yamaha Grizzly ATV Forum
May 23, 2009
Grizzly 700 Reverse rev-limiter Override Mod - Page 3 ...
May 21, 2009
Hitting rev limited/ slow speed.... - Yamaha Grizzly ...
May 20, 2009
reverse rev limiter - override witch bypass - Yamaha ...
Oct 22, 2008
More results from www.grizzlycentral.com
Rev Limiter - GrizzlyOwners.Com Yamaha Grizzly Forums
www.grizzlyowners.com > Grizzly 660 > Modifications
Old 06-30-2008, 10:43 AM Thread Starter. modrak .... jasson450r is offline ... hey guys! how do you do this rev limiter mod on a 06 660 griz? i'm interested in ...
How to bypass reverse switch Grizzly 700(speed limiter ...
? 1:03
https://www.youtube.com/watch?v=l8nn5Z4cuN0
Dec 25, 2015 | Yamaha Motorcycles
New Fan not coming on 2007 Yamaha Grizzly 450 Auto 4by4
make sure all your connections are hooked. and that no wires are damaged
Oct 05, 2013 | Yamaha 2007 Grizzly 450 Auto 4x4
Backfires when you try to rev up engine,
check fuel flow and check spark at spark plugs
According to an "ATV Rider" 2009 article, "When the Grizzly was introduced in 1998 as a 600cc machine, the top was blown right off the displacement wars of the time."
It was replaced in 2002 with Yamaha Grizzly 660, an even bigger engine derived from the well-established all-terrain vehicle (ATV) Yamaha Raptor 660R.
Grizzly's 660 cubic centimeter (cc), four-stroke, liquid-cooled single overhead camshaft, five-valve engine performs well in open country, but sometimes it causes serious problems for owners.
Before you call a Grizzly dealer, however, trying a few tricks in your garage can save you a lot of time and money.
Check the fuel level.
Locate the fuel meter indicator on top of the multifunction display.
If it does not work properly, open the fuel tank, and push the Yamaha 660 Grizzly side to side.
Ensure the fuel is not contaminated by water or rust.
If you have not driven your Grizzly 660 for a long time, drain the tank completely, and fill it with a fuel tank cleaner.
Check fuel hoses for cracks or leakage.
The hoses should be soft and simple to bend.
Replace those that show any sign of wear.
Check the compression.
Screw a compression tester into the spark plug hole, and press the electric starter button.
If no compression exists, contact a Yamaha dealer.
Wipe wet or dirty electrodes with a dry cloth.
The spark plug gap should be checked regularly
Correct the spark plug gap.
Measure the gap with a wire thickness gauge.
If necessary, adjust it to 0.8mm using a screwdriver or replace the spark plug.
Use only a Yamaha-specified spark plug.
Check the Yamaha 660 Grizzly's battery.
Operate its electric starter.
If the Grizzly starts quickly, then its battery is in good condition.
If the engine turns slowly, check the battery lead connections, and you may need to change the battery.
If the engine still does not eventually start, your Grizzly is beyond home repair.
Jul 23, 2013 | Yamaha 2005 Grizzly 660 Auto 4x4
2003 yamaha grizzly 660 4x4 atv, right side rear axle/cv joint came lose at differential
Yamaha Grizzly 660 2002 2008
get one of these..If you are going to try the repair yourself....
.this is serious, ....
there MIGHT be damaged components that need to be inspected by a professional.
Mar 17, 2011 | Yamaha 2004 Grizzly 660 Auto 4x4
Location of alternator on 700 grizzly 4 wheeler i
The altenator is usually 3 phase. It is unlikely that 2 phases have gone down, more likely the diode pack has failed. Check the rectifier/regulator before taking the engine to bits. It may save some time and money on spares you don't need!
Feb 16, 2011 | 2008 Yamaha XT 660 R
Yamaha grizzly 600 not firing
Check spark clean the carb check valve clearances if none of those you have an electrical problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brandon_79b580f5a99c4386
May 16, 2010 | RTO 200cc Full Size Four Wheeler ATV
Welding Tools Logo
50 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
