Question about Sierra SHIELDS LIVE WELL HOSE, Hose, Livewell, 3/4" x 50
I have a 1978 monark boat and the front livewell is not working at all what should i do?
It will not drain the water out of the front livewell at all. What should I do?
Live well pump Key Largo boat what switch turns it on& off
On some boats there is a manual handle to direct water to either wash down or livewell. If you hear a pump running, but no water in livewell, look for that manual handle in the hose plumbing.
Sep 10, 2017 | Boating
How do I locate where water is leaking in from - 1983 Olympic - water is showing up on the cabin floor
livewell hoses have a habit of leaking.if you could leave it in and put the boat on trailer you might see where it leaks back out.
Sep 16, 2014 | Boating
Boat manuals
Live wells usually have water come in when the boat is at rest if they are lower than the waterline. They may drain when the boat is on plane.
Aug 26, 2014 | Boating
My 2 livewell pumps on my boat run but dont pump water to the livewells
have you tried reversing the wires. if wrong they run backkward and will never pump water .
Aug 18, 2014 | Boating
Why is there a small hole in the side of the left hand side of the hull on a 2002 regal lsr1800
it could be livewell drain(overflow) or even bilge outlet.check inside of boat.
Jun 30, 2014 | Boating
Lost livewell plug what is the size I need for 176 Strartos
I believe they're all the same. Drain plugs, live wells, etc. any good screw down drain plug will do. I don't like the flip ring type personally. Hope this helps.
Mar 15, 2014 | Stratos 176 VLO
Boat taking on water
maybe a livewell line
May 29, 2010 | Boating
1998 Champion 181 bass boat in California...It appears that livewell is leaking into bilge,...and the aeration pump is not working? Could it be the pump? or a fitting at the base of the live well...by the...
try "duct tape" the fittings and drain to seal those areas, refill and see if water is still leaking, if so it's your live-well is cracked somewhere, and can be repaired on the inside with fiberglass resin..... if not then most likely the fittings/pump/hoses/etc....yes its a pain .Champions don't have alot of room to access any of that...got a Ranger myself....hope this helps and see you on the water....GL
Jul 06, 2009 | RTO Oar Sockets
Sierra SHIELDS LIVE WELL HOSE, Hose, Livewell, 3/4" x 50 Logo
Top Sierra Plumbing Experts
Donni Steen
Tom Chichester
Are you a Sierra Plumbing Expert? Answer questions, earn points and help others
