Question about Haier Commercial Cool 12,000 BTU Heat/11,000 BTU Cool Portable Air Conditioner
Why is it not blowing air
Just put it in new location plugged in and it is not blowing
  • 54 Answers
You said it doesn't blow air - but does it show any sign it is getting power such as a pilot light or LCD display? If not:
First, check the power outlet - is it live? Does the plug fit securely? No extension cord, right?
Second, plug the unit into another outlet - preferably the one where it worked before, if it's not too far away. Don't use an extension cord.
Third, let it sit for 24 hours. Sometimes moving a portable unit can require a waiting period before use.
Fourth, check all the access panels to make sure they are snug. Sometimes they have microswitches that shut off power when opened. Moving the unit could have dislodged one.
Posted on May 15, 2014
Mower will not start
Is the plug getting fire to plug. The coil maybe bad.
Apr 23, 2017 | Cars & Trucks
My ac unit fan is blowing but it is not coming threw the vents . Do I have the wiring plugged up wrong or what is the problem I just put the new motor on the unit because the fan was not moving at all now...
Sounds like your motor is going backwards. Most new motors have two short wires plugged into two more short wires that you can reverse to make the motor go the other way.These reverse wires are located on the motor housing next to where all the other wires come out of the motor.
May 11, 2011 | Heating & Cooling
I have a 2003 toyota corolla. My AC would blow cold air for a min or two then when the compressor shut off it would no longer blow cold air or come back on. A new compressor was put in it but it did not...
the ac clutch relay is the problem. It is located in the under hood fuse box. It is a $10 part. The relay will make a clicking sound when activated but the contacts inside are burnt causing no electrical flow to the ac compressor. Simply unplug and replace. The relay is labeled M/G CLT .
replace or blow out the cabin air filter as well. It is located behind the glove box. Instructions are in your owners manual.
Oct 31, 2010 | 2003 Toyota Corolla
Sfv_artificethe motor feels like it is not running on all 8 cyli have pretty much have done everything. i put new plugs and cleaned the throttle bodylooked for disconnected air intakes/ vaccumlines changed...
maybe you have a clogged fuel filter find your fuel rail under hood and on it theres a pressure relief valve make sure it is got good fuel pressure .......air pump is the pump for your air ride suspension i believe and it cold be blowing because one of your air rides is out or the computer that moniters suspension is messed up
Sep 24, 2010 | 2002 Cadillac Deville
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Air conditioning and blowers not working, fuse blows immediatley after changing. there was a clicking noise heard before fuse blew. No display on dash unit. (2000 passat 1.9TDi Sport)
Try unplugging the blower resistor, located under the passenger side, under dash area, put a new fuse in and see if the fuse opens (blows). If it does not blow then unplug the blower located in roughly the same are and plug the resistor back in if it blows then it the resistor if not it's most likely the blower motor.
If the fuse blows when both resistor and the motor is unplugged the you need to unplug the a/c head unit and see if it still blows(open fuse)
Hope this helps
Mar 17, 2010 | Volkswagen Passat Cars & Trucks
Ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Dec 16, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
My blower is not blowing out any air , i have checked fuses and there is a good contact from the wires behind the heating module, the heater still gives off warm "air" but oes not circulate. i also need to...
the problem is your blower relay. take your car to any autozone store and they will put it on their computer for free, verify your problem and even assist you in replacing the relay which is merely unplugging the old one and plugging in the new one
Oct 01, 2009 | 2002 BMW 5 Series
Poor gas mileage
if it is a fuel injected engine, try putting in a bottle of fuel injector cleaner to remove any sludge that may be in the injectors.Check the PCV valve too. it is located on the valve cover with a hose . It should blow air one way and not the other. if it blows both ways. it is damaged. it is supposed to be air tight one way.if that does not work, do a cylinder compression test. For that you need a compression guage which can be bought at any autoparts store.Check how much compression your engine needs to have if it is a V6 or V8 or 4 cylinder.You did not specify.If it is below normal for your particular engine, the rings may be wearing down or the rod bearings.
Nov 20, 2008 | 2001 Chevrolet S-10
Haier Commercial Cool 12,000 BTU Heat/11,000 BTU Cool Portable Air Conditioner Logo
65 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
