Question about Canon Imagerunner 2525
How can I clear Error code E000000 - Canon Imagerunner 2525
    New Friend:
It's Working Thanks A lot
Posted on Feb 24, 2015
  • Lenin Hudiel
    Lenin Hudiel Feb 24, 2015
    you are wellcome, please tag my answer al helpful
    Master:
  • Canon Master
  • 556 Answers
First clear that error from service mode. Press additional function
press 2 and then press 8
press additional function again
service mode should appear in screen
select "clear"
select "engine"
select "Errlcr"
select ok.
unplug power cord for a few seconds and restart the machine,
try to make some copies if problem persist replace the fixing heater assembly
Posted on Jun 05, 2014
5 Suggested Answers
  • 57 Answers
SOURCE: Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Posted on Sep 03, 2009
spinal
  • 287 Answers
SOURCE: error code E000000-0001
Hello nelco9,I can help you clear the code easy enough. But there is a strong probability the code will come back almost immedietly.Copiers use high heat and pressure to bond the toner to the paper.It is of course critical to accurately monitor this high temp as to insure against fire.The code E0000000-001 means that for any number of reasons the copier did not or could not reliably monitor this temp.Now, something as simple as a momentary variation in the power to the plug the device is plugged into can cause this code as the plug voltage and/or frequency is sufficient to interfere with the copier's ability to track the temp, so lets hope for the best.Trust me there are so many fail safes involved in this process that the copier will properly shut down if the problem is serious.Ok,locate the'ADDITIONAL FUNCTIONS" button on the op panel.It is just to the right of the 9 key pad.Press it, let go, then the numbers 2&8 simaltaneously,let go, then ADDITIONAL FUNCTIONS again.You will see a new screen.Press "copier". Tabs appear at the top.Press the "function" button.New screen again.Press "clear".New screen.Press "ERR" .Press "OK" in the lower right corner.Now if you TRULY know where the main power switch is (right rear of copier about halfway down) then power the copier off.If in doubt simply unplug the copier.When you turn it back on the copier will attemt to start up as normal.If it does then congrats !!.If it fails you will need a new fusing unit which can run as high as $800. I truly hope I have helped you.Take care.
Posted on May 02, 2010
  • 525 Answers
SOURCE: Inherited this 2200 w/ new political office. Was
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Posted on Feb 04, 2011
pintu_umaro
SOURCE: Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Posted on Apr 19, 2013
How to solve error E000000 in canon ir 2530i The error say: E000000 error code below
Enter the service mode *28* then choose by the arrows Clear then Engine then ERRCLR press ok then turn off and on the printer .your code will disappear .
Jan 05, 2018 | Canon Office Equipment & Supplies
E000000-0000 solutions in you tube
E000 is a heater temperature fault. (fails to increase)
Try to clear the code in the service mode.
If that does not work, check the fuser's main thermistor and see if it an open circuit.
Other problems:
Main power supply PCB or DC controller PCB is faulty.
Door switch is faulty.
Aug 11, 2014 | Canon IR 3300 Digital Copier
How can I fix Photocopy, Error code E000000 Cannon IR 2525
VOLTES IS LOW CHEK YOUR POWER SUPLY & VOLTES
THEN
CLEAR ERROR CODE
Feb 19, 2013 | Office Equipment & Supplies
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Canon error code E000000-0000
Some of possiblle causes:
The heater has an open circuit.
The thermal fuse has blown.
The High-voltage PCB has a fault.
The DCNT PCB has a fault.
FIRST:
under service mode * 2 8 * :
COPIER-FUNCTION-CLEAR-ERR-OK
Turn off and on.
if that doesnt help replace fixing film assy.
Jun 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Im getting error e000000-0000
ok the Error code is to do with your fixing unit, you need to go into service and clear the error then reset machine should work again.
do a search for clearing fixing unit error code on your canon copier, wont be to hard to find
canon copier tech
Mar 30, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Imagerunner 2525 Logo
239 people viewed this question
old marine
old marine
