Question about La Crosse Home
How do I bypass the solenoid on my pepsi machine model # LC (ILL) 90 9 so I can release the bottles without coins?
My tracker is stuck in park, won't shift , the shifter will not move , the car starts now what?
Most vehicles have a locking solenoid on the shifter that prevents you from moving the shifter unless the brake pedal is pressed. If the vehicle will start, but the shifter won't release when you press the brake pedal, then either the switch that activates the solenoid on the brake pedal is bad, or the solenoid itself is bad. Most vehicles also have an emergency release mechanism for the shifter that can bypass this restriction. There is usually a slot or recess that has a release button that you can insert something thin and release the shifter manually. Check your users manual for details as the method can vary from year to year and model to model.
May 21, 2016 | Cars & Trucks
Is it true that Pepsi has taken "Under God" out of Pledge of Allegiance?
No, it is a hoax. It is based on something roughly similar on a Dr Pepper can 10 yrs back.
Mar 29, 2015 | Pepsi , Cola Bottles and More Vol #2 By...
Can I bypass the neutral line going to a coin acceptor in a Maytag washing maching?
sounds like you can't be out much if you try it and it doesn't work
Dec 18, 2014 | Maytag Washing Machines
Just bought brand new whirlpool top loading commercial washer and dryer with the coin sli
i think the answer is in the question....
you have bought a machine for multiple users (apartment. camping sites)
did you get a key for the coin box?
if so. just keep coins handy run them through the coin-op.
otherwise, you may need to employ an electrician to bypass it
May 16, 2014 | Washing Machines
Coins in drain pump on washing machine. Coins can be seen through plastic drum of washer, how do i get them out/
Without your model number this is a stab in the dark.. for a front loading HE machine. Look at the lower panel of the washer. It should have 2 tabs that you can relase with a putty or butter knife. Open the panel... then locate the white or black flat faced filter. Rotate the filter 90 Deg CCW.... knowing full well this is going to make a water mess. Be prepaired.... cake pan works great! Then pull the filter out and remove the coins. Make sure your reach back inside with your fingers to ensure there is noting on the pump impeller blades. Once clean... reinstall the filter by pressing it straight in.. then thruning it 90 deg clockwise to LOCK it in place. Leak test!!!!!! Close panel and use normally.
Thanks for choosing FixYa,
Kelly
Apr 27, 2011 | Kenmore Washing Machines
How to remove lower front panel on kenmore 90 series dryer dryer runs a few minuites heats up then shuts off i think it needs lint cleaned from inside unit i'm trying to get inside to do this
On my 7 year old Series 90 Dryer, I
- unplug the dryer
- use a flash light to locate the two black metal spring clips (located about 3 inches from each end of the lower panel along its top edge). They can be seen in the crack between the upper and lower panels.
- use a putty knife, or similar tool, to press down each clip while pulling out that edge of the panel.
- The panel slips off the lower clips easily.
- on some models there is a lone yellow wire with a connector on the end. If it is unconnected to anything, don't go nuts thinking that you have disconnected a wire by accident. Its one of those unused wires on some models.
- collect as many coins as possible before you vacuum the inside of the machine. Leaning the machine forward can often slide hidden coins to the front. BE SURE YOU CAN LEAN THE MACHINE WITHOUT HAVING IT FALL ON YOU. Otherwise, plan on collecting the coins from the vacuum cleaner when you finish.
- replace the panel by first threading the panel on to the lower clips, then closing the panel. CLICK, CLICK. FINISHED.
Congrats you have cleaned it, possibly avoided a house fire and added to the mad money collection. Hope this helped.
Mar 16, 2009 | Kenmore 73952 Gas Dryer
Home Logo
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
