Question about Transmission & Drivetrain for Dodge Dakota Cab SLT
There is a noise in my transmission it squeaks when it goes into reverse,
    Sergeant:
    Champion:
  • 259 Answers
Possible bad universal joint
Posted on May 14, 2014
2004 jeep grand Cherokee limited 4.0 squeak from transmission when first engaged in reverse. I have verified this with a mechanics stethoscope, the warmer it gets the quieter it gets, sound is louder
great but no transmission stated.
a/t
42RE? or 45RFE?
check bolts on flex plate? (TC flex plate to fly juncture)
seem like a torque reaction , caused squeak, ( i cant hear it so...)
the mounts, spray them all with silicon spray, try that first before
a new $2-3000 trans..
U-joints? spray them next, if now gone ,bingo>
keep in mind noise can telegraph. that means
noise can travel far , from origin. fooling any one with a stethoscope.
Nov 03, 2014 | 2004 Jeep Grand Cherokee
Noise in reverse
sounds like a brake issue but paul is right it could also be the u-joints I suggest taking a look at the brakes first though also is the noise coming from the rear or front of the vehicle?
Mar 22, 2014 | 1998 Ford F150 Regular Cab
Squeaking Noise
to check if belt spray water on the belt and if the squeak goes then adjust /replace the belt. When the belt dries out the noise will be back unless you do something to fix it.
Jan 28, 2014 | 2007 Toyota Camry
SQUEAKY!
Petroleum will rot bushings, you may consider a car wash with and undercarriage sprayer and see if noise goes away. This may indicate a bushing problem if noise goes away. If not, ball joint probably.
Jun 28, 2013 | 1999 Ford Expedition
I have 1999 ford explorer rear wheel drive when i crank it up an put it in drive it starts beeping
Not really enough info from you about your car or problem. A rough guess would be the transmission mount is loose, worn, broken or otherwise damaged. When you say "beeping noise", is that like the sound you hear when a bus or emergency vehicle is placed in reverse, or is it more like a mechanical squeaking or chirping type noise? Check your transmission mount. That may be your problem. Hope this helps you out.
Aug 24, 2011 | 1999 Ford Explorer
What causes a squeak noise that increases in frequency during ilding speed, upon acceleration in automatic transmission, when in reverse, Park and Neutral ?
if it does not comingand from the engine check all the belts and altenator pully, air compresor pully,power steling
May 18, 2011 | 1992 Cadillac Seville
Mechanic advised torque converter caused transmission to go bad. will go in reverse but no power. also when driving, goes from 1st to 2nd with difficulty then when going in to 3rd, makes an awful squeaking...
well based on the symptoms you need a new or rebuilt transmission, as to the cause, yes the TC can cause a failure, but it is a guess on there part is my opinion
Nov 10, 2009 | 1989 Dodge Dakota 2WD
Tranny makes noise in 1st gear then goes away in 2nd gear
It could be the U joints in your drive shaft. If there is no problem to the transmission as to it's performance other then the squeaking noise in revers or slow speeds. Most likely it's going to be the U joint, the factory U joints don't have grease fitting and only have a life time of service.
The u joints may have reached it's life time and need to be replaced. You have two of them and most of the time it's just one that goe's bad, but changed them both since the drive shaft needs to be removed from the truck.
Good luck and hope this helps.
May 13, 2009 | 1997 GMC Yukon
Whining noise when engaging 1st or reverse.
i had a nissan pickup that would whine in all gears except 4th...it started out with 1st then reverse then went to the rest...solution was new transmission...or rebuild cause the syncronizers or the gears them selves are being chewed up...the new transmission was cheaper then a rebuild. or take it to somewhere that will do free diag on the transmission.
Mar 29, 2009 | 1996 Nissan Pickup
Transmission & Drivetrain for Dodge Dakota Cab SLT Logo
37 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
