Question about Compaq Presario M2000 Notebook
Vertical lines on my laptop screen
It started with one line, now they have covered the whole screen that I cannot see anything.
  • 24 Answers
If you are talking about thin line or lines you probably have a bad display panel, expensive to replace
Posted on Jun 23, 2009
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Vertical screen lines
I suggest that you check the connection of the motherboard and your computer's screen because it has something to do with it. Or if resetting the connection won't do anything then I suggest that you let a tech check it.
David
Jul 18, 2013 | NEC Computers & Internet
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
Vertical lines o my desktop
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
Compaq Presario M2000 Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
