Question about Xerox Office Equipment & Supplies
What is xerox error msg 07,010.43:10289 ?? - Xerox Office Equipment & Supplies
    New Friend:
  • 4 Answers
Broken drum cum shaft , proccess drve gear assembly
Posted on May 17, 2014
Testimonial: "Thank you so very much for your expertise. I have to decide what is more cost effective: to fix or to buy new. Thanks"
Xerox work centre 7328 giving error of replace black toner after guinue toner
If toner is new- check that it is in correct position- still printing fine? Error message continues, disregard msg- they are trying to sell you more ink
Apr 19, 2013 | Office Equipment & Supplies
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Screen displays "printer error fuser temp"
Disassemble fuser unit and inspect thermistor and thermostat for dirt or damges, and heater lamp for damages.
Good luck.
Feb 08, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Xerox phaser 3200mfp We are able to fax out, but all inbound receiving faxes are getting a busy signal and not coming through. There is no error msg of any kind. please help.
Get a older phone and hook it up. Try to call that number and see if you get though. My guess would be this is a prefix error (not putting a 1 in front of the area code, ect.)
Jun 24, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Error msg 13,200.41:27966
The printhead has problem gone bad. The error 13,200 tells us that right jetstack is over temperature and shut down. (27966 is your page count)
You probably need to buy P/N 017K04540
May 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Error message
07,005.47 PM_FAULT_DM_CAM_POSITION_ERROR
"The Drum Maintenance home sensor actuated, but not at the expected time. "
Inspect the drum maintenance drawer lift pins for wear. That is the black assembly you remove to clean out excess ink and also holds the maintenance kit roller and IC chip.
There are two arms that stick out on the sides....if they are worn on the bottom, or grooved out, that will cause this error.
Nov 21, 2008 | Xerox Phaser 8200 Laser Printer
ERROR WITH XEROX C118
Your machine is still working with msg? How many copies already made after displaying this?
Toner sensor may faulty cross check with same module.
Aug 28, 2008 | Xerox CopyCentre C118 Copier
ERROR MSG CH
A CH code means the toner cartridge is not being sensed.
Could just be not seated properly. Open the front and remove and reseat the toner cartridge.
It may be empty also.
Aug 24, 2008 | Xerox WorkCentre XL2130f Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
No Cartridge error message on Xerox PE120i
The cartridge's sensing is bad or either the cartridge is refilled one (then u need to replace the crum)
omnipresent
Nov 04, 2007 | Xerox PE120i Laser Printer
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
