Question about Samsung AQV18JA Classic Wall Mounted Mini Split Heat Pump - 18,000 BTU
I have two of these units with remote located in one room. All of a sudden, both remotes work the same unit. How can I "reprogram" one of the remotes to control the other unit?
  • 54 Answers
Here is a link to the service manual for your unit. Look for section on programming unit identification for the remote.http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.quietside.com%2Fclassic%2Fdownloads%2FService%2520AQV18_24%2520JAKCV.pdf&ei=uwh1U5PpNM6iqAaHr4DQCA&usg=AFQjCNEAs6FdSrr1lSDgNuNZ_9zvmycdKA&sig2=pILXHK1-yJa9ugqScI1evw&bvm=bv.66699033,d.b2k
Posted on May 15, 2014
  • 13433 Answers
SOURCE: Sensor in my Samsung Split
The receaver is most likely broken?
Posted on May 24, 2008
bobotfel
  • 236 Answers
SOURCE: I have a split system
Replace receiver board or if you have a spare unit try to transfer the receiver board to the defective one and test the remote to confirm the unit problem.
Posted on May 30, 2008
  • 143 Answers
SOURCE: THE REMOTE CONTROL UNIT FOR
A new remote.
Posted on Jul 24, 2008
  • 250 Answers
SOURCE: THE MONITOR OF INDOOR UNIT DISPLY ALL THE
This could be caused by a blown circuit breaker or fuse inside the unit, a damaged compressor or fan motor, faulty wires connecting the compressor or fans to the control board unit, a faulty or hung relay on the control board (this can sometimes be solved by tapping the relay with a screwdriver), or the starter capacitor for the compressor or fan motor.
Posted on Sep 20, 2009
  • 400 Answers
SOURCE: i start my as 12 samsung ac with the remote or
If you look carefully at the remote there is a reset button, try resetting it and make sure you have new batteries.
Posted on Nov 18, 2009
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Sears Model 139.53985D - remotes suddenly do not work - can't reprogram them either. When activated or trying to reprogram the unit clicks but nothing starts. Any ideas?? Thanks
Make sure the batteries are good in your remotes. Next it might be your openers logic board. Get the numbers off the unit and look for a replacement on ebay as there are plenty of used good parts out there, heck even new ones if you want to spend the extra cash.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
My remote suddenly does nothing
This may sound stupid but have you replaced the batteries in the remote? In either case if the remote is a universal remote (has different buttons usually across the top to select different devices) then the manual should give codes to reprogram it. If you cannot get it working with new batteries and reprogramming then the remote might have gone bad. If the remote does appear to be bad then I would just buy a new universal remote and program it for your equipment since they are not very expensive.
Mar 12, 2008 | Bose 3 2 1 GSX System
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Samsung AQV18JA Classic Wall Mounted Mini Split Heat Pump - 18,000 BTU Logo
108 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
