Question about Riccar RC1100 Compact Vacuum
How do you remove the cover of a Riccar RC1100?
2 Suggested Answers
  • 25 Answers
SOURCE: riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Posted on Mar 26, 2008
How do i replace a hepa filter for riccar 8955?
Recline the handle backward. There are two little catches on the filter cover, pull them to remove the cover. Remove the filter and replace.
Apr 27, 2014 | Riccar 8955 Upright Vacuum
Replace power cord on riccar 8955
Remove the bag door cover, remove the screws holding the cover over the switch and wires coming into the body of the vacuum. Remove two screws holding the cord in place, unhook the old cord and install the new one the same way the old on was
Apr 14, 2014 | Riccar 8955 Upright Vacuum
Accessing the motor on a riccar radiance
On a Radiance you will need to remove the screws going through the bottom of the vacuum nozzle housing which hold the cover on. Remove the cover and remove the screws holding the cover that goes from the brush roll to the lower motor. When you remove this cover tpyou will be able to see into the fan of the lower direct air motor to remove the obstruction. If it is in too far. You may have to pull the motorand open up the fan. This is not a hard thing to do but. If you have never done it, it can be a confusing job that may be best left to your Riccar dealer.
Mar 05, 2014 | Riccar 8955 Upright Vacuum
Riccar sunburst vacuum wheel
There are little prongs that hold the wheel on. New wheels are inexpensive if it needs to be replaced. Break the prongs off with a skinny screwdriver to remove the wheel. The new wheel will just snap in place.
Nov 15, 2013 | Riccar RC1100 Compact Vacuum
No suction in hose
There is most likely something stuck in the hose.
Jun 06, 2013 | Riccar Model RC1100 Canister Vacuum...
How do I find the opening to change the bag on the Riccar RC 1100
Just above the hole where the hose goes there's a squarish part to where your hand should go. It should just pull upwards.
User manual download (FREE and in pdf form:)
http://www.riccar.com/ftp/whitepapers/1100_OwnersManual.pdf
Jun 17, 2009 | Riccar RC1100 Compact Vacuum
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Riccar RC-1100 won't power on?
try a different power cord, otherwise it is a thermal issue. if it is a thermal issue, call or e-mail tech support, and send it in. otherwise you could get it repaired @ any local vacuum cleaner dealer
Apr 07, 2009 | Riccar RC1100 Compact Vacuum
Riccar rc1100 won't turn off
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Vacuums Logo
18 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
