Question about Texas Instruments TI-5045 SVC Calculator
How do you add new paper roll to adding machine
New paper roll will not feed through do you have any suggestions?
Please be specific. Cash register tape, Adding machine tape,etc.
Jun 13, 2017 | Paper Roll Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
How do I put roll of paper in adding machine Canon P100-dh
hi. the is a little slot located in the back side of the machine insert the tip of the paper there and press the upper arrow in the keyboard. .
Mar 07, 2015 | Canon Office Equipment & Supplies
What kind of paper does the Casio DR-220 hd calculator use?
The Caiso DR220HD takes a Universal 2-1/4" x 150' Calculator Paper Rolls
Calculator and adding machine paper rolls.
2-1/4" wide. 150' in length. 1-ply.
Your local office supply store shoudl carry this. or order online here:
Free Shipping On Casio DR 220 HD Paper Roll DR220HD
http://www.worldclassink.com/Casio-DR-220-HD-Paper-Roll-printer21507-ift198.html
Aug 12, 2014 | Casio Office Equipment & Supplies
Ibico 1232 adding machine won't print totals
For mine to print I have to hit either the subtotal key, or the total key. (# and/or * )
Jun 05, 2013 | Universal Office Adding Machine/Calculator...
How do you load the paper on this adding machine?
    • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
    • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
    • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
    • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
Jan 30, 2011 | Canon P23-DHV Calculator
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer1.gif assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Mar 21, 2008 | Ibico 1202 Calculator
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | Texas Instruments TI-5045 SVC Calculator
Texas Instruments TI-5045 SVC Calculator Logo
35 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
