Question about Fujitsu LifeBook AH532 Notebook
I have a fujitsu laptop, and half of the keyboard no longer functions. How do i fix it?
I am unsure what the issue is. It seems to be connection related, and it only happens to the right half of the keyboard. Essentially all the letters and buttons on the right half, minus the numerical keys on right. The keyboard was replaced, however the same issue occurs with the new keyboard. The drivers were uninstalled and reinstalled with the same issue.
3 Suggested Answers
  • 86 Answers
SOURCE: Keyboard sticking
you need a new keyboard search on ebay it will be easy to replace
Posted on Oct 19, 2009
  • 2567 Answers
SOURCE: i have the letter g
There is not so much that could be done to repair a keyboard. Replace the keyboard with a new one.
Posted on Sep 21, 2010
Fujitsu Fn key stuck laptop PC Laptops
The Function keys can be usually disabled by a manufacturer provided program, in the control panel.
You can also probably download a replacement from Fujitsu.
Fujitsu America Support
If it is a hardware problem, it should be coming up as a keyboard error on start up, it will not say which key is stuck, so this is probably a software issue.
The manual is listed below for the function key use.
http://solutions.us.fujitsu.com/www/content/pdf/usermanuals/sseries/S7010,S7010D_ONION_USERGUIDE.PDF
Dec 12, 2012 | Fujitsu Siemens LifeBook S7010 Notebook
Keyboard no longer lights up and the sound from the fn button no longer works
It is possible that the connection between the keyboard and the laptop is the issue. If you can figure out how to remove the keyboard, you will see it is connected to the laptop with a flat ribbon cable. Open the plastic clip that holds the flat cable (carefully!!) and then reconnect the cable. If that doesn't fix it, you may want to contact asus to get a replacement keyboard, or just plug in a usb keyboard.
Hope this helps!
Joe
Jun 04, 2011 | ASUS 90-A4C1K1000 Keyboard
My Fujitsu siemens esprimo mobile M9400 laptop screen was fade (white color). When I connect to extra monitor via monitor output, computer is working well. How can I solve this problem?
Dear User,
Good day, maybe you need to press the function key of your laptop plus(+) the split monitor key in your keyboard it is usually placed in F5 key.
Apr 16, 2011 | Fujitsu Siemens Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
My laptop has recently stopped functionin an even charging after my ex messed with my msn. im unsure exactly what she did help please
Hi:
I don't think that messing with msn. will cause a charging or functioning problem, as most of the time that sort of thing is caused by damage to the power jack on the back of the laptop. Check out this area, and see if the connection seems loose. If so, it can be an expensive repair,as often the motherboard is damaged, and best case, the motherboard has to be removed to solder the connection. There is a possiblity the ac adapter has failed too.
Oct 25, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Keyboard is not functioning
go to control panel then system then device manager look for you keyboard uninstall it then scan for hardware changes the machine sould detect the keybaord and install it automaticly
Oct 12, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Laptop software written in Chinese
Your cheap way out would be to contact Fujitsu. They can sell you a Windows XP CD for that laptop that is in English. If you buy your own, it will cost you more. The one that they sell you will only work on that brand of laptop. It will be less than half the cost of a store bought Windows XP though.
The problem with the Asian keyboard; You will have to have them sell you an American keyboard. I am sure that the laptop is at least worth the cost.
I hope that this Fixed your problem.
Jun 08, 2008 | Computers & Internet
Fujitsu laptop 6240
You can connect an external keyboard and see if the problem persists. That would rule out a keyboard problem. Also connect an external mouse to see if the system is frozen or the keyboard/mouse combo are just not working. If its a keyboard problem, chances are you either spilled something on it or the connector came loose from vibration or general use. Unscrew the keyboard and reseat the cable. See if the problem is resolved.
Aug 17, 2007 | Fujitsu (G281065802)
Fujitsu LifeBook AH532 Notebook Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
