Question about Garden
Poppet valve missing in gun
Does the pump need back pressure ie trigger not engaged.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Not sure I understand. What is your model #.
pressure is created by forcing the water through the tiny hole in the spray nozzle. The gun is a simple open and close valve.
Posted on Jun 11, 2014
Monster80
  • 460 Answers
SOURCE: When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
Posted on Apr 06, 2009
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
  • 174 Answers
SOURCE: trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
Posted on Aug 03, 2009
  • 8 Answers
SOURCE: let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Posted on Jul 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Pressure Washer
Derek, Hi and welcome to FixYa. I am Kelly.
I just now happened across your post and note it is 3 months old. Hopefully you already have the problem solved.
If not.. looking at the pump history of having the un-loader valve replaced it sure seems that the current un-loader valve is sticking. When an un-loader valve is removed the internal housing is sanded smooth and everything about the un-loader valve is coated with Lubriplate #105 White Grease. I get the feeling that who ever did the un-loader valve repair failed to sand / clean the housing and use White Grease for the final assembly.
You should remove the valve... Sand the housing and get some Lubriplate #105 white grease (auto parts store) in a tube. Lubricate it liberally and reassemble it. If should work fine after that.
Thanks for choosing FixYa,
Kelly
Posted on Dec 07, 2010
What is a bypass unloader
According to epowerwash.com:
"The unloader valve diverts water flow into bypass when the trigger gun valve is closed. Unloaders may be designed to respond to either an increase in pressure or a change in flow. The unloader valve may also be used for variable pressure adjustment."
More information here:
All About Unloader Valves ePowerWash
Jun 06, 2014 | Alfred Karcher Pressure Washer
KARCHER 2400 PSI HONDA ENG GC SERIES 160 RESIDENTIAL PREMIUM
Hello there.
If the washer is loosing pressure then it needs to be looked at under warranty, im not sure where the fault would be, but another expert may well know.
If you don't get any suggestions then i would take it back and ask for a replacement or repair.
Hope this helps.
May 09, 2008 | Karcher 2500 PSI Pressure Washer
old models yes, new models no
May 14, 2014 | Briggs & Stratton Garden
Pressure Washer
any leaks from connection at pump to gun and wand assembly if so the valve is detecting leakage and open up again without u squeezing trigger it builds up in the head.if your trigger gun is leaking internally then you will need to replace the gun this unit uses a trap pressure unloader valve
Jul 15, 2013 | Garden
020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.
Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely.
Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles.
I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!
Don
Mar 23, 2012 | FAIP Garden
My tahoe willonly start in the morning if I prime carb & now not at all
The first thing you need to check is fuel pressure with a fuel pressure gauge. You need a minimum of 56 PSI (preferable a lot more) for the vehicle to start.
If fuel pressure is low than the pump is usually the problem.
The CPI injection has poppet valves that deliver the fuel to the back of the intake valves. The poppets require the minimum fuel pressure to open. If the pressure is off by less than a couple of pounds the poppets will not open.
Priming to get the vehicle started and then the vehicle continues to run is a classic symptom for this problem. Since the poppets are under vacuum with the engine running they require less pressure to open.
Oct 01, 2010 | 1998 Chevrolet Tahoe
Karcher electric power washer
Dear, cb_scherer,
I can only give you some hints because I do not know the type and model of gun. First if your gun is put together with rivets and not screws, this could not be serviced. In this case you have to buy a new one. Now if you have screws, normaly Torx(T15) or sometimes Philips....you can open the gun to have a look inside. Some guns have an adjustment for correcting the travel of the trigger. This is a simple alen screw. Now if damage has been caused to the pin that is pushed by the trigger, then also a new gun is a must. In my opinion I rarely service guns. Infact the only guns that are serviceable ,..are of industrial machines. As I said, I do not know what type of machine you have and so I do not know the type of gun you have.
My general advice, is to buy a new gun. A gun is not that expensive. And working with a faulty gun not only in time will damage the machine, but it is also not safe!!
Regards,
Fulltech.
May 22, 2009 | Karcher K2.26 Electric Power Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
