Question about Home
Shower problems I have a zy-137 shower and steam cubicle The steam wasn't commingled through the valve and I turned it to have a look one it has come unscrewed and there is a visible hole and I am unable to use the shower as the water will go through the hole Will the whole shower cubicle have to be taken apart to gain access to the steamer can it be fixed Kind regards
  • 717 Answers
Somehow you have to get that pipe coming back through the wall of the shower.
There is a pipe with threads on it that the nozzle threads onto.
Once you can get that pipe back through the shower wall you can thread the steam nozzle back on.
If the steam nozzle has been replaced onto the threaded pipe you can trouble shoot your steamer as to why there is no steam coming out.
ROD
U S Parts Center
Posted on May 25, 2014
4 Suggested Answers
  • 50 Answers
SOURCE: Due to city water line
Most modern multi function shower heads cannot be disassembled. Spray water into the outlet part to remove larger bits, then leave in vinegar and water solution (50:50) overnight to remove calcium build up.
Posted on Sep 06, 2010
  • 280 Answers
SOURCE: How do I get rid
Hello, i use citric acid on my swimming pool (plastic) stains caused from hard water, both rain and bore, i managed to get some from Bunnings (in Australia) but have been told you can also get it from supermarkets.
Posted on Mar 30, 2011
ftw1952
  • 10319 Answers
SOURCE: the pull valve that directs
it is full of lime and scale from mineral deposits.
either chip it away to clean or remove and replace the spout with a new one which is the easiest thing to do instead
Posted on Aug 20, 2011
I have a ceda digital shower cubicle with a touchscreen The touchscreen has cracked and am struggling to find the right replacement model
Is there any kind of code on the rear of the control pad?, its hard to see from the image if the silver surround is just a fascia and the control pad in behind it is perhaps one that is recognizable. Certainly a Chinese product.
Feb 28, 2014 | Home
I have a steam shower cubicle and when the water is switched off it still drips from the shower head,it only stops if I run the hot water tap in the sink
Most likely the issue is the unit is not isolating the water when turned off. Inside the shower valve will be an on off valve that will likely look like thus 06a0e29a-a81e-4b1d-b746-6d8bf0394774.jpg if you can locate one of these and replace your dripping will be resolved. Alternatively if this is only dripping from the larger monsoon in the roof, this can drip for a while after use as it holds a fair bit of water.
Can also try selecting one of the other features when not in use such as he back massage jets ( if you have a 3 dial valve) if it still drips then the problem will almost certainly be a replacement on/off valve
Steam Shower Parts Spares
Jan 04, 2014 | Kohler K-1698-G Brushed Chrome Tandem...
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
Shower goes cold intermittently like there is a restriction in hot water delivery. Plenty of hot water when it comes back, but the cold blast is not fun. No shortage of hot water for long showers or...
Has nothing to do with the expansion tank, the expansion tank whole enough air so that when the heater heats the water it does not build up pressure. You know from school that you can compress ait. you CAN NOT compress water. When you haet water it expands until it turns to steam. So lets rule that out.
First look at all the plumbing in the house where there is a cross conection. This would be like a shower valve that has a personal shower head on it. and you turn of the water using the personal shower handle and not the valve at the wall. This then would let cold water to go into the hot water side piping.
Most people do that with out knowing it at the laundry sink. they put a hose on to was the dog and forget to turn off the faucet and then BANG cold water in the hot side.
Go around the house and turn off all the faucets and valves by using the handles. no add on things.
Now last could be the shower valve itself. . Do this happen in just one shower or all of them???
If its just the one and you spend the day doing the walk around, even check the bidet if you have one
its the valve. you need repair to that.
Best of luck in your hunt Tom
Sep 08, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Aqua steam shower cubicle not doing as it should when pushing control buttons example press radio button shower comes on etc
If you had it installed by some one have them come back and rewire it correctly and if you did it get out the wiring diagram and check your wiring.
Feb 10, 2011 | Plumbing
Steam shower wont turn on getting a flashing temp on controller in shower
Hi I am with Mr. Steam Tech Support please call 800-767-8326 and ask for tech support. please have your serial number and we will be able at assit you in getting your unit up and running
Thanks
Mike
Mr. Steam
Product Support
Nov 14, 2010 | Mr Steam Ms Super 1e Steam Shower...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
I have a magic chef side by side and my freezer fan wont stop run
1) Either the ice cubicles are not filling with water, or 2) The ice is not dumping into the bin after it freezes.
To check for #1, you should be able to look into the ice cubicles to see if they're filled with water (or ice). If they are, go to #2. If not, you've probably got a defective water valve.
If the cubicles are full of ice or water, but don't dump out, the most likely culprit is the cubicle heater, which slightly heats the walls of the cubicles so that the ice can be more easily ejected into the bin. Unless you're VERY mechanically inclined, this is a job best left for an appliance repairman.,
thank u
rate me
Jul 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Home Logo
111 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
