Question about Kenmore 22622 Top Load Washer
Need part diagram for Malber P28 washer
Need pump part # for my Malber washer mod # P28
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
Hi Folks, I have just realized why my Malber needed repairs after I first moved it seven years ago; I didn't have the transit spacers when I bought it second hand from a Polish couple. I have just moved...
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in local telephone directories OR stay on line and search for 'malber washer service' for instance or 'malber washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 16, 2011 | Malber WD1000 Front Load Washer/Dryer
Press start button nothing happens - malber p28
If you've determined the unit has power, does it fill with water, or just nothing ?
Sep 29, 2009 | Washing Machines
Water runs into drum when machine is off!
See what happens if you completely remove electrical power from the machine (by turning off at the wall, or unplugging it) If the water keeps coming in even with the power off(easily the morelikely outcome), then you need to replace the fill valve. On most machines, you get to this by taking the top cover off and looking inside at the point where the water inlet hose comes in. The plastic fitting that the hose screws onto is in fact part of the valve that you want to replace (you'll recognise it by the row of solenoid valves - 2 or 3 of them, each with a pair of wires on the top, and a hose trailing off to some part of the machine coming out the bottom). Fitting a new one is quite easy - just make sure you mark all the hoses and wires before you remove the old valve so you can put them all back in the right place. If the problem goes away when you turn the power off (a far more unlikely result), then you need to look for problems with the programmer and wiring. Tracking these down is a lot more involved, and potentially more expensive. A.
Jun 07, 2009 | Malber P28 Front Load All-in-One Washer /...
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
My washer won't empty
Does the pump spins ? Try to rotate pump's pulley manually. If it doesn't turn freely (frozen or stiff), check for foreign object inside the pump. In case you will not find an object that prevent pump's spining, it should be replaced. Good luck!
Aug 22, 2007 | Malber P21 Front Load Washer
Kenmore 22622 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
